Power Up Off-Grid with Bougie Bro
Back to overview
A practical guide to building an off-grid power station using wind energy, suitable for off-grid applications and backup power options
  • 2
    Set Up the Battery Box
    1. Place the 12V LiFePO4 battery into the battery box.
    2. Connect the battery terminals to the box's connectors using a screwdriver. Ensure all connections are tight and secure.
    3. Use the multimeter to verify the voltage of the battery.
  • 3
    Install the Wind Turbine
    1. Select a location with good wind exposure for mounting the wind turbine.
    2. Assemble the wind turbine according to the manufacturer's instructions.
    3. Mount the wind turbine using the provided mounting hardware. Ensure it is securely fastened.
    4. Connect the wind turbine's output wires to the MPPT controller.
  • 4
    Connect the MPPT Controller to the Battery Box
    1. Use the wire strippers to strip the ends of the wires from the MPPT controller.
    2. Crimp the appropriate connectors onto the stripped wire ends.
    3. Connect the MPPT controller output to the Anderson plug input on the battery box. Ensure a secure connection.
  • 5
    Set Up the Power Inverter
    1. Clamp the red (positive) lead from the power inverter to the positive terminal on the battery box.
    2. Clamp the black (negative) lead from the power inverter to the negative terminal on the battery box.
    3. Ensure all connections are tight and secure.
  • 6
    Connect the Solar Panels to the Battery Box
    1. Use a DC to Anderson adaptor to connect the solar panel output directly to the battery box.
    2. Plug the Anderson connector into the battery box's Anderson input/output connection.
    3. Ensure a secure connection without the need for an additional solar controller.
  • 7
    Test the System
    1. Turn on the wind turbine and ensure it is generating power.
    2. Check the voltage indicator on the battery box to confirm the battery is charging.
    3. Turn on the power inverter and connect a device to the AC outlet to test if it is providing power.
  • 8
    Secure All Cables and Connections
    1. Use cable ties to organize and secure all wires and cables.
    2. Apply heat shrink tubing to any exposed connections and use a heat gun to shrink it in place.
    3. Wrap any additional connections with electrical tape for extra security.
  • 9
    Monitor and Maintain
    1. Regularly check the voltage indicator on the battery box to monitor the battery level.
    2. Periodically inspect all connections and cables for wear and tear.
    3. Clean and maintain the wind turbine to ensure optimal performance.
  • Discussions
