Lower Section of Pole Secured
08/13/2024 at 06:47 • 0 commentsThe pole was unscrewed allowing me to secure the lower section to the ground. I used a Green Concrete mix that was designed for my region. However, different areas and climates may need a different recipe.
My Green Concrete recipe.
I ordered the wrong size Anderson connections. My system needs SB50 which is designed for 50 volts. The replacements are on the way
Mid Point
08/02/2024 at 05:03 • 0 commentsOutstanding Items from my last log
- Anderson Power Connections need to be installed and hooked up from the wind turbine to the Wind controller
- Assess if any additional tools are needed to mount the Wind turbine on the repurposed flag pool
- Measure out suitable wire to run approximately 15 feet of wire from wind controller to Power Supply input
Actions Taken and Updates
1. Anderson Power Connections Installation:
- Components Ordered:
- 175A Battery Connector for 175A 600V Plug, Quick-Connector Disconnector Housing 2-Pole (Red, 4 AWG):
- Reason: These connectors are high-current capable and provide a quick disconnect feature, making maintenance and installation easier.
- MJPOWER Anderson-to-8mm Extension Cable 10FT/3m 14AWG Wire 8mm DC Power Plug Adapter:
- Reason: Provides flexibility in connecting various components and extends the reach of the Anderson connectors.
- JooFn 175A Plug Mounting Panel with Cover for Anderson SB175 Connectors Flush Mount Recessed Plate (Red-1pc):
- Reason: To ensure a secure and professional mounting of the Anderson connectors on the panel.
- Action Taken:
- Anderson connectors will be installed to facilitate easy connections and disconnections between the wind turbine and the wind controller.
2. Tools for Mounting Wind Turbine:
- Assessment:
- No additional tools were identified as necessary after reviewing the mounting requirements for the repurposed flag pole.
- Update:
- The current tools are deemed sufficient for mounting the wind turbine. Adjustments will be made based on the specific installation process.
3. Wire Measurement and Installation:
- 4 AWG Battery Cable 4AWG Gauge Pure Copper Battery Inverter Cables with 3/8 in Lugs Both Ends Power Inverter Wire Set (9in):
- Reason: Ensures minimal resistance and efficient power transfer over short distances.
- 4 Gauge 4 AWG 20 Feet Red + 20 Feet Black (40 Feet Total) Welding Battery Pure Copper Flexible Cable Wire:
- Reason: Provides the necessary length and flexibility to connect from the wind controller to the power supply input.
- TKDMR and Sanuke Wire Lugs Ring Terminal Connectors Ends Heavy Duty for Battery Cable Lug Wire Electrical Eyelets with 3:1 Dual Wall Adhesive Heat Shrink:
- Reason: To ensure secure and durable connections at the terminals.
- Action Taken:
- Measured and prepared the 15 feet of wire required for the connection from the wind controller to the power supply input.
- Selected 4 AWG wire to handle the current capacity and minimize voltage drop.
Update:
- (My buddy offered me and allowed me to pick up some solar panels, resulting in this beneficial upgrade to the project. Solar Panel Integration) (Change and Unintended Upgrade):
- Thunderbolt Magnum Solar 100 Watt Solar Panel Kit:
- Reason: To provide an additional renewable energy source for charging the battery, complementing the wind turbine setup. I will not use the solar controller as it needs to be powered and hook the Solar DC connection to an adaptor that will connect to my Adderson input/output connect.
Additional Components and Their Purposes:
- Cordless Heat Gun:
- Reason: For shrinking heat shrink tubing on connections, ensuring they are insulated and protected from environmental factors.
- LeMotech Junction Box:
- Reason: To house and protect electrical connections, ensuring they are kept safe from dust and moisture.
- VenxyKod Bus Bar 5/16" Power Distribution Block 250A 12V Terminal Block 4 Studs Junction Block with Cover:
- Reason: For efficient distribution of power and organization of connections, providing a clean and safe installation.
- ANDERSON POWER PRODUCTS 111038G2 INSERTION EXTRACTION TOOL:
- Reason: To facilitate easy insertion and extraction of Anderson connectors, ensuring secure and reliable connections.
Summary:
- Anderson Power Connections: Components ordered and ready for installation.
- Tools for Mounting Wind Turbine: Current tools are sufficient.
- Wire Measurement: 4 AWG wire measured and prepared for the required 15-foot run.
- Solar Panel Integration: Solar panel kit ordered and ready for integration as a beneficial upgrade.
The components were chosen to ensure a robust, flexible, and secure setup for the wind turbine power station. The selected items provide high current capacity, easy installation, and weather protection, ensuring the system's reliability and longevity.
Initial Set Up
07/21/2024 at 10:17 • 0 commentsThe following items were successfully set up and or installed:
- Wind Turbine
- Invertor
- Battery
- Battery Box/ Power Station
The below items were successfully tested and running as expected:
- Battery
Next Steps
