BLDC controller uses an STM32F446RET microcontroller.
Since the motor is rated for a nominal 2500 watts, the motor driver is designed to operate at a nominal 48 V operating voltage and a nominal 50 A operating current.
12 IXFH320N10T2 MOSFETs were used in the circuit for switching and power balancing, depending on the need.
STM32F446RET
IRS21867
INA229
IXFH320N10T2
Order Your JLCPCB
We have the PCB design and it's time to order the PCBs. For that, you just have to go to JLCPCB and click the “Instant Quote” button. JLCPCB is the sponsor of this project. JLCPCB (ShenzhenJLC Electronics Co., Ltd.) is the largest PCB prototype enterprise in China and a high-tech manufacturer specializing in rapid PCB prototype and small batch PCB production.
You can order at least 5 PCBs for just $2. Upload the Gerber file you downloaded in the last step to fabricate the PCB. Upload .rar file or you can also drag and drop Gerber files. After uploading the .rar file, you will see a success message below the successfully uploaded file. You can inspect the PCB in Gerber viewer to make sure everything is ok.
You can view both the top and bottom of the PCB. After making sure our PCB looks good, we can now place the order at a reasonable price. You can order 5 PCBs for just $2. You can see what the individual options are and what they are used for, on JLCPCB's user-friendly website. Of course, the price will vary depending on the PCB board size and the extra services you choose. In order to have it produced in the cheapest and shortest time, I suggest...
Sagar 001
mbsg99
