The level indicator repeats Leoniv's design (link below) but is implemented in Altium. I plan to remove everything unnecessary from the board. One of the devices to be removed is a parallel port, which is designed to read the state of the tape recorder and display on the indicator. In my case, the control will be carried out exclusively through R485.
The indicator firmware will be completely reimplemented.
h2w
