Considering DIN connectors
A project log for Renovation of the E004 audio tape recorder
A low-cost, high-quality tape recorder with a cross-board architecture.
h2wh2w 07/30/2024 at 08:260 Comments
The Soviet MRN-14 connectors were great, but are obsolete today. The use of DIN41612 will require a slight modification to the chassis. However, it is not important if you build your own tape recorder from scratch.
