Gerber_Purple_Cyclops_Side_View_LEDs.zip
This is the Gerber file for the side LED PCB. This was generated using EasyEDA for JLCPCB multi-color silkscreen. Important: Due to a bug in the side led component of the schematic, the negative and positive labels for the LEDs are reversed. When you solider the LED, make sure the Anode (+) is connected to the negative labeled pad. You can use a multimeter on continuity test to verify the traces (routes).
x-zip-compressed -
3.90 MB -
08/04/2024 at 16:02
