There are 4 distinct sizes of test pads. I'll call them tiny, small, medium, large
The large pads appear to relate to the battery cells
The medium pads appear to be internal voltage test points
The small pads I'm not sure yet
The tiny pads I'm not sure yet
TP18 changes from 0 to 5VDC when in test mode
Each cell has a S# pad that removes the cell from the circuit. This causes a
001734242,AFE voltage invalid␍
AFE = Analog Front End = U6 = QB7693003
message to be displayed on the serial output.
