The EcoSift operates using centrifugal force to efficiently separate sand from microplastics, rocks, and other debris. When the bucket is filled with water, microplastics float to the surface while heavier natural debris settles at the bottom. This instant separation allows us to easily skim off the microplastics from the water’s surface with a specialized scooper, effectively removing them from the environment.
Jackson.shell
TAIBHSE DESIGNS
TechSpiderbot
sabrinanader
