Here is a 3d animation of how the bucket would currently function. First, the sift is filled with sand and placed into the bucket. Then the lid is attached and the user spins the crank to utilize the centrifugal force to sift out sand, from the microplastics, rocks, and other debris. Then by filling the bucket with water the microplastics will float and the other natural debris will stay at the bottom thus instantly separating the microplastics then we use my scooper to clean the top layer with the microplastics and remove them from the environment.
