Design:
- The basis for this project is a sound module (DY-SV5W), tilt switch and speaker.
- It uses a small lithium-ion battery, charging board and a voltage boost module to get to 5v for the sound module.
- The electronics assemble onto a "skid" and then are inserted into the milk jug housing.
- I'm sure this could have been built several different ways.
- My goal was to do this with off the shelf components, while trying to keep it simple.
- Tilt switch - This a simple switch that is triggered by turning it a certain angle. It's a lo-fi way of not needing to use an IMU or microcontroller.
- Sound module (DY-SV5W) - this is a low cost sound module, which can store and play mp3 files. It's fairly small and can drive a 5w speaker.
Parts used:
- Sound module - https://amzn.to/4bmViUF
- Charge module - https://amzn.to/3W3DUzR
- Boost converter - https://amzn.to/4cK9UOT
- Battery - https://amzn.to/3AaE4gq
- Tilt switch - https://s.click.aliexpress.com/e/_DE5bFYT
- Speaker - https://amzn.to/3xtN3IJ
- On/off switch - https://amzn.to/45JU1G8
- Screws - https://amzn.to/4eUQOb0
- E6000 glue - https://amzn.to/3AdJ8Av
- Electronics screwdriver kit - https://amzn.to/4dsfvds
Franklinstein
William
4D Makers
Junluan
Xavier W
Great project! Thanks for sending it to the tips line -- I wrote up a post and it should publish soon. :)
