Record Sound
- For this specific sound module, it uses a micro-SD card to store mp3 files.
- To record a new sound, you'll need to remove the card and save your mp3 to it.
- The file name will need to be 00001.mp3 in order for it to play when the "IO1" pin on the sound module is grounded.
- The sound module dip switches should be set to: 1 = up, 2 = down, 3 = down
- Adjust the volume with the grey rotary pot, using a philips screwdriver.
- This link gives more info on the sound module: DY-SV5W MP3 Music Player Voice Module | 5W Amplifier (icstation.com)
