bagged and tagged
10/14/2024 at 21:04 • 0 commentsWith the help of a wonderful friend the ~90ish red/green/blue simple add-on kits are all now packed! It's fairly simple to solder, definitely beginner friendly!
Boards are done - 25% LEDs work
10/11/2024 at 19:03 • 0 commentsFor the event I had ordered 3 boards each in green, red and blue. The blue version has the order number on the front. All of them only have one of the LEDs correctly connected, for the other three you have to botch a bit.
But 1 LED seems plenty strong already anyways.![]()
now with LEDs
08/29/2024 at 20:19 • 0 commentsbut like a kit from https://www.blinkyparts.com/ - just add legged RGB LED faders and some hot glue!
Some actual thoughts
08/29/2024 at 19:07 • 0 commentsThe connector can probably be SMD as well, as it wouldn't hold as much stuff anyways. Stickers on shirts might work the first day, but this is a three days event. Supercon can be overwhelming, so taking time to program a name tag might already be too much. There could be some slightly glowing white LEDs instead, like @arturo182 uses in his marker badges that he gave out at chaos camp. But then this badge might need some stacked boards instead. So white silkscreen feels like keeping it simple.
First!
08/29/2024 at 18:59 • 0 comments![]()
davedarko
