LED Flashlight
LED Flashlight for everyone
Please read because of Battery
I read a lot of people using this battery http://www.ebay.com.au/itm/111196510869?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 to run their LED.
DONT USE IT.
This battery is not for operating the LED. Its a normaly mobilephone battery ( existing of 9 small batteries)
The energie the LED needs to run, is not high eneough (discharge energie).
When LED takes to much Energie, the protective circuit release and battery cant used anymore.
So please use LiPo battery.
Every Cell (6 Cell) of the battery has to charge seperate (by using the balancer connector)
So you need a spezial Charger http://www.hobbyking.com/hobbyking/store/__216__408__Chargers_Accessories-Battery_Chargers.html
What i used to upgrade is a battery controll (cells should not discharged under 2,9 V DC)
Contact me if you have questions
Led
Led cooling
Fan
Led driver
LiPo battery
LED reflector lense
Aluminium case
View all 7 components
  • LED V2
    Norman • 07/30/2014 at 19:39 • 0 comments
    For Details, see my LED Flashlight Project V2
  • Upgrade
    Norman • 07/21/2014 at 08:14 • 0 comments
    Upgrading the aluminiumcase to a smaller and much lighter one. from 131x256x91 to 68,5x297x77. and quater of the weight.
    also without a fan, but with a poti to slow down the energy because of the heating
View all 2 project logs
  • 1
    Step 1
    comes as far as i can.
    ehm, give me one week
View all instructions
