after the warmup with #hello my name is SAO I wanted to do something artsy with controlled blink. Han Solo was inspired by a cybertruck simple add-on, that used a lot of exposed copper that's covered in "silver" HASL. After starting a list of possible simple add-ons for the #Supercon 8 - Add On Contest , I very much liked the idea of an Han Solo simple add-on, but wanted to add some LEDs as well. Some brainstorming later I came up with this "dimetric" view, basically using 45 degree angles for depth. The animation is roughly based on the blinking sequence of the defreezing scene in ROTJ. Realising that the black solder stop mask was see-through if no copper was behind it, I used that to make his face glow when the de-freeze animation hits.
davedarko
Alex
Tom Nardi
blinkingthing
rrace001
LOOKS AWESOME! You nailed it with the light sequence and the shine through on the face!
