Setting sensibility of trackballs
09/11/2024 at 18:19 • 0 commentsInside of MAME menu it's necessary less the sensibility of the trackballs
50% it's perfect
Real Tehkan World Cup in action
09/11/2024 at 18:06 • 0 comments -
Setting multimouse again
09/07/2024 at 18:08 • 0 commentsAfter creating a specific system for the game, I tried it and the mice didn't work for playing. And I had the same configuration that I used in MAME. I managed to make it work by adding the three lines that you see highlighted in the image. Normally they would have been created automatically. You always learn new things :)
Start system with retrobat
09/07/2024 at 17:17 • 0 commentsChange retrobat INI with the option "Launch retrobat by shortcut in start..."
Arts
09/07/2024 at 16:42 • 0 commentsAdd arts inside the folders
background
logos
All the files with the same name included in the code es_systems.cfg
es_system.cfg
09/07/2024 at 16:36 • 0 comments<system>
<name>Tehkan World Cup</name>
<fullname>Tehkan World Cup</fullname>
<manufacturer>Arcade</manufacturer>
<release/>
<hardware>arcade</hardware>
<path>~\..\roms\Tehkan</path>
<extension>.zip .7z</extension>
<command>"%HOME%\emulatorLauncher.exe" -gameinfo %GAMEINFOXML% %CONTROLLERSCONFIG% -system %SYSTEM% -emulator %EMULATOR% -core %CORE% -rom %ROM%</command>
<emulators>
<emulator name="libretro">
<cores>
<core>mame</core>
<core>mame2016</core>
<core>mame2014</core>
<core>mame2010</core>
<core>mame2003_plus</core>
<core>mame2003</core>
<core>mame2003_midway</core>
<core>mame2000</core>
</cores>
</emulator>
<emulator name="mame64"/>
</emulators>
<platform>arcade</platform>
<theme>tehkan</theme>
</system>
Adapting Retrobat
09/07/2024 at 16:35 • 0 commentsAdding arts to new system :) TEHKAN WC
To add a new custom system, you need to edit the es_systems.cfg file located in the retrobat\emulationstation\.emulationstation folder
Test 3D Azteca stadium
09/06/2024 at 17:03 • 0 comments -
Instructions
09/06/2024 at 16:53 • 0 comments -
Easter Eggs
09/06/2024 at 14:34 • 0 commentsWhen you finish playing and have to enter your name, try typing TOMI and the letter I will be like putting the end to finish typing. You will be able to hear the music you would hear when you win the final. If, instead, you type MICH using the same methods described above, you will be able to hear music never heard before in any level of the game!
