MINI ARCADE TEHKAN WORLD CUP WITH TRACKBALLS 2P
Recreating a small and updated version of the legendary 2-player trackball arcade game TEHKAN WORD CUP
Public Chat
For the recreation, we will use a mini PC of no more than 50€ and a screen size of 8". For the trackballs I will reuse the work I did with the all-in-one arcade controller. I will recreate a stadium in 3D and I will discard putting any glass or protection. In short, retro nostalgia and hours of fun for a home version.
Tehkan World Cup (1985) – A Classic Arcade Soccer Game
Tehkan World Cup is an arcade soccer game released in 1985 by Tehkan (now Tecmo). It was a pioneer in the genre thanks to its fast-paced gameplay and its unique dual trackball control system, which offered an unprecedented level of precision and speed for its time.
🕹️ Controls and Mechanics with the Trackball
The trackball was the key to Tehkan World Cup's gameplay. Unlike traditional joysticks, this control system allowed for more natural and responsive movements.
🏃 Player Movement
  • Spinning the trackball gently made the player walk.
  • Spinning it quickly increased speed, allowing for sprinting.
  • Changing direction abruptly helped players lose their markers faster.
⚽ Shooting and Passing
To shoot or pass, players had to strike the trackball with different intensities and directions:
  • Short Pass 🟢: A soft tap in the desired direction made accurate ground passes.
  • Power Shot 🔥: A fast spin of the trackball combined with a strong strike resulted in a powerful shot.
  • Curved Ball Effect 🔄: Spinning the trackball diagonally or in a circular motion before shooting made the ball curve, confusing the goalkeeper.
  • Lob Shot 🏹: A quick flick of the trackball from bottom to top lifted the ball for a lob shot.
🔥 Popular Tricks and Strategies
🎯 Unstoppable Shot from the Wing
  • Running toward the edge of the penalty area and then spinning the trackball diagonally inward resulted in a near-unstoppable cross-shot.
🌀 Banana Shot (Deadly Curve)
  • Making a semicircular motion with the trackball before shooting added an incredible curve to the ball, tricking the goalkeeper.
💨 Lightning Sprint
  • Spinning the trackball with both hands at maximum speed made players run at full pace, outpacing slow defenders.
🥅 Olimpico Goal (Scoring from a Corner Kick)
  • Adding spin to the trackball while taking a corner kick could curve the ball straight into the goal.
🏆 Fun Facts and Anecdotes
🔥 Intense Arcade Battles It was common to see players completely absorbed in the game, furiously spinning the trackballs to gain speed and power. Some even wrapped their fingers in tape or wore gloves to avoid blisters after long sessions.
🎮 Broken Machines and Damaged Trackballs Due to the intense gameplay, many arcade machines suffered wear and tear on their trackballs. Some arcade owners even placed warning signs asking players not to hit them too hard.
⚽ Birth of Rivalries Tehkan World Cup became a hotspot for fierce competition in many arcades. Informal tournaments were organized, and top players were constantly challenged by new contenders.
📜 Legacy and Impact
Tehkan World Cup was not only a hit in its time but also laid the foundation for future arcade soccer games. Its innovative control system and fast-paced gameplay inspired later titles like Tecmo World Cup '90 and SNK’s legendary Super Sidekicks series.
Its impact still lingers in the memories of those who spent hours spinning trackballs with all their might, chasing that perfect goal. 😆⚽
STL PARTS
https://www.thingiverse.com/thing:6962734
Gamepad_XINPUT.ino
ino - 7.25 kB - 02/28/2025 at 07:03
Download
View all 23 components
View all 76 project logs
  • 1
    Print all parts.
    All parts are printed face up. Trackball parts have to be colored in the laminator with the corresponding color. I used a bambulab A1 with AMS 4 colors. The layer height used is 0.2mm and the infill 30%. I only used supports for the stadium roof.
    Label all parts on the side that is not visible.
  • 2
    Welding inserted nuts
    With the help of a soldering iron and a tip large enough to be able to insert and remove the nuts easily. For the speakers, USB, fans and power supply, the M3 nuts are used, for the rest, the M4 nuts are used.
  • 3
    Assembly the base
    The base is made up of two pieces joined together by two M4 nuts. I also used glue to keep them well joined. It is important for the rest of the construction that it remains as a single piece. Unfortunately, the size of my printer is a handicap. You can also use a welding iron with a flat tip and join the two pieces by heating the matching face. I did not do this, but it is very common to join PLA pieces together.
View all 14 instructions
SrRubio wrote 03/29/2025 at 19:59 point
Thank you!
Richard Hogben wrote 02/27/2025 at 00:11 point
The stadium enclosure is really cool
