The Matrix is finally working. 'Only' four LEDs needed to be replaced before the whole string was working. Early testing Firmware is running! I also used PlatformIO and Visual Studio Code which was surprisingly nice and fast to work with.
PCBs (made by Aisler) are solderd, but not yet tested and there is also no Firmware yet
Here are some images. There is still a frame around the PCB. This frame will be removed later. The coin is a quarter USD. The inner PCB is tiny (8x11mm
