Keyboard Development Boards (QMK-VIA)
STM32F411 (LQFP64) and RP2040 Modules for QMK and VIA Keyboard Software Development
Keyboard Development Modules:
Development boards to assist in development of QMK/VIA based keyboards from scratch using RP2040. Rev 1.x uses a 30 pin 1.27mm and a 3 pin (RGB and power) connectors, Rev 2.x uses one 34 pin 1.27mm connector.
Optional Basic Keyboard PCB:
A bare-bones basic Keyboard which includes, HS Connectors, Diodes, RGB Leds, Caps Lock Led, Rotary Encoder and RGB leds (∼80%, 98 keys including 10 macro keys), is included in the project. It can be used with any development module having enough GPIOs. The basic Keyboard PCB prototypes have been tested and are perfect, see GitHub link for files.
Module to Keyboard connection via a 1.27mm pitch connector or FFC / FPC ribbon connector. The second revision removed the test RGB leds and updates connector to 34 pin. The extra pins are to supply additional current as a single ribbon strand is a little lacking.
Tested both versions, fully functioning on 19 Feb 2025...
Hardware: Micro, Keys, etc...
Micros: RP2040 and STM32F411RETx (default is RP2040)
Software Support: QMK/VIA
Switches: MX type hot-swappable
Keys: Up to 119 Keys (including Macro Keys) + Encoder Switch
Rotary Encoder: Volume / RGB.
Tools:
  • Kicad version 9, release build...
  • Plugins: KLE Placer (saves so much time with layout, a must have).
  • QMK Configurator
Other references:
keyboard-layout-editor.com
See GitHub Kicad files and Code...
Added a 3d printed case (in two parts), tweaking before uploading. It has a section to hold the module board secure and should be the most economical solution. Files for a FR4 plate are also available, they cost about €5 from PCB Way...
stm32_64pin_dev_board.kicad_pcb_bom.csv
Current BOM (may change)...
Comma-Separated Values - 2.54 kB - 12/26/2024 at 14:39
Download
  • Adapter Board
    Michael O'Toole03/21/2025 at 08:33 0 comments
    Testing the Module with the 34 pins 1.27mm connector is almost impossible so I added an adapter board.
    This board is breadboard friendly if you use pin headers, with pin sockets you can use common 2.54mm jumpers. Note, this adapter is for modules with the 34 pin connector...
    The development board is fine for testing code and now you can check button action with the extender. Once your happy, you can plug it into one of the basic keyboard with the 34 pin socket in the project and you have a QMK/VIA keyboard with macros and RGB...
    Gerber Files
  • Status
    Michael O'Toole03/20/2025 at 22:20 0 comments
    To date I have designed three version of the Keyboard Development Module, each having slight updates.
    The first provided four test RGB leds and used a 30 pin connector and a three pin connector for the RGB, the second removed the RGB leds, simplified the Boot, Reset switches and changed to a single 34 pin 1.27mm connector.
    The third and last version, is identical to the second but changes the position of the connector making connection to the basic keyboard easier and more natural.
    All three modules work perfectly for developing and testing QMK/VIA code but once you are finished your code development, I want to be able to use them on the actual keyboard. To this end I provide several basis keyboards containing all the necessary parts allowing connection to one of the modules.
    Note, I've only tested the first two modules as the final design has not yet arrived but as it only relocates the connector I don't see any problems.
    The final version pictured below.
    It appears to be more cost effective to use a module as opposed to building a keyboard including the full electronics from the beginning.
    You can hand assemble the keyboard as all components are pretty easy to hand solder and getting the modules fully assembled is cost effective, less than €20 and the keyboard is about €10. The FR4 Plate cost about €5 (all prices are less shipping).
    Note, I used both JLCPCB (Keyboard & Plate) and PCB Way (Assembled Modules) as they offer better prices depending on size, assembled etc...
    With a full 3d printed case, the full cost for a keyboard should be less than €45, mind you, you have to purchase a minimum of five boards and pay for shipping... ideally you could get five friends to join in.
  • Schematic
    Michael O'Toole02/24/2025 at 17:43 0 comments
    Preliminary, quick reference schematic image (Kicad files can be found on my github ).
    Same for all versions, more or less...
  • Final Design Module PCB (Module34C)
    Michael O'Toole02/21/2025 at 14:34 0 comments
    The original module with the built in RGB test Leds is perfect for developing code but the two different connectors aren't really necessary if after the development you then use it to control/make an actual keyboard.
    I have upgraded the module to use a single 34 pin connector and replaced the two switches with pin headers. The extra pins also allow adequate current for the RGB Leds, considering your PC's USB supplies 2 Amps Max @ 5V.
    In tests at full brightness, the keyboard draws just under 1.2 Amps from the USB. Each pin on the connector is rated at about 1 Amp (we now use 3 pins for supply and ground).
    There are two major advantage to using a Module and Basic (bare-bones) Keyboard as apposed to getting a fully assembled keyboard...
    1. Reduced Costs as Keyboard can be assembled by hand (parts are easy enough to solder)...
    2. The fully assembled Module is relatively inexpensive, hand assembly would be very difficult...
  • RP2040 Keyboard Development Module and Basic Keyboard Test Results
    Michael O'Toole02/13/2025 at 15:32 0 comments
    As the new Basic Keyboard PCB arrived I set about testing it with the Keyboard Development Module (RP2040version), and I can report a complete success, both worked perfectly...
    1. Tested current Software ✓
    2. The new "Basic Keyboard PCB" ✓ (change code to reverse volume up/down)...
    3. RP2040 Development Module ✓
    4. Keyboard Functionality ✓
    5. Macros ✓
    6. RGB ✓ (need to edit code to change RGB position)...
    I tested the basic keyboard functionality with various programs and VIA support on the usevia web site...
  • Another Dev Module
    Michael O'Toole02/11/2025 at 00:09 0 comments
    Base on Minimal Design Example REV2 on raspberrypi.com
    I added USB-C and 30 pin keyboard to attach to my basic keyboard PCB.
    What can I say, I like tinkering ... :)
  • New ISO Layout
    Michael O'Toole01/27/2025 at 15:23 0 comments
    Testing the new RP2040 Module in usevia.app
    Note, encoder in now on the  right, it replaces the pause keyboard button as it is never used...
    Michael O'Toole01/25/2025 at 17:52 0 comments
    Assembled boards arrived today (from PCBWay). A quick test reveals I didn't screw up as they worked perfectly, including the RGB.
    The 2040 having more available GPIO's simplifies the design process and with the driver:vendor option RGB is a breeze and the flashing is easy with drag and drop, definitely the way to go for your first keyboard project.
    One thing for certain, without a microscope or camera with zoom, hand soldering these tiny devices would be a major challenge for anyone and not recommended for your average hobbyist or old engineers like me.
    The cost of 5 boards (3 completely assembled and 2 empty), including courier amounted to $87.34. That's about $22 per assembled board which is as good as it gets... I should have got all the boards assembled, I will in future.
    Next Step:
    It would be tempting to just add the electronics from the dev board to the main keyboard PCB and call it a day, but as I now have 3 perfectly good RP2040 Keyboard Modules, I think I go with a basic keyboard PCB, that is a board with only the switches, diodes, RGB leds and the 30 pin connector. This also has the advantage of being able to repurpose it for use with other modules.
    There is no difficulty in hand assembling the bare-bones board as the diodes, hot-swappable connectors and RGB are easy enough to hand solder, thereby reducing the overall cost.
  • Bare-bones Keyboard II
    Michael O'Toole12/27/2024 at 07:19 0 comments
    Working on a new version of the bare-bones board
    Improvements:
    • Changed RGB to SK6812MINI RGB (much easier to hand solder).
    • Moved Rotary Encoder to right side in place of the pause button (as it is rarely, ever ever used).
    • Pin compatible connector, serves both STM32 and RP2040 development modules.
    Reasoning:
    The bare-bones keyboard PCB is intended for development along with either the STM32 or RP2040 development modules. My main aim was to simplify development and limit potential problems by separating development into two parts, then combine to create the final keyboard.
    Nothing is wasted, as I can combine any module with a bare-bone board to create a working keyboard.
    I will update this log when I complete the new board...
  • Additional Images
    Michael O'Toole12/26/2024 at 14:27 0 comments
    Place holder for additional images
    Cols/Rows numbering from keyboard-layout-editor.com and usevia app (encoder on left)
View all 15 project logs
