Italian Word Clock
It tells you the time with RGB leds, already working on a talking version that also moves the hands
An italian word clock based on Raspberry pi and addressable LEDs, packed in an IKEA frame
  • 1 × IKEA Sannahed picture frame
  • 1 × Raspberry pi Zero 2 W
  • 1 × 1m Addressable LED strip 144 LED/m with WS2812B LEDs
  • 1 × Wire Resistors (Fixed) / Zero Ohm Jumpers
  • 1 × USB power supply
View all 7 components
  • Software setup
    esenes • 10/13/2024 at 20:20 • 0 comments
    Start with a fresh installation of raspbian OS, with internet access (either via ethernet or setup the wifi connection when you flash the SD card).
    During the installation, create a sudo user called clockPi'.
    Make sure that you run
    sudo raspi-config
    and select the appropriate time zone !
    Keep the time synchronised:
    Install the NTP service to keep the time synchronized via web. In this implementation there is no NTC module, so we will have to rely on the web for that.
    Run in a terminal
    sudo apt-get install ntp
     then configure it (for servers in Italy)
    sudo nano /etc/ntp.conf
    and write inside
    server ntp1.inrim.it iburst
    server ntp2.inrim.it iburst
    server time.inrim.it iburst
    then save and exit. Restart the service with
    sudo service ntp restart
    and you should be good. Check the status with
    sudo service ntp status
    Dowload the scripts from github:
    Create a folder to host the scripts called "wordClock"
    cd
    mkdir wordClock
    download the scripts in the Scripts folder at https://github.com/esenes/Word-clock, and copy them inside the wordClock folder in the raspberry pi.
    Install the Adafruit-Blinka library:
    First of all you need to get the Adafruit-Blinka library
    sudo apt-get update
    sudo apt-get -y upgrade
    sudo apt-get install python3-pip
    sudo apt install --upgrade python3-setuptools
    sudo apt-get install python3-full
    then reboot the raspberry pi.
    Create a virtual environment for the python script to run:
    Move inside the script folder
    cd
    cd ./wordClock
    and create a virtual environment called "env"
    python3 -m venv env --system-site-packages
     once it's done, activate the environment and install the neopixel libraries
    source ./env/bin/activate
    Install the libraries for the neopixel LED strips:
    pip install rpi_ws281x
    pip install adafruit-circuitpython-neopixel
    And as last touch go to disable the audio on pin 18 if that's what you will be using. Go to /boot/firmware/config.txt and set dtparam=audio=off
    Test that everything runs:
    /bin/bash /home/clockPi/wordClock/run_clock.sh
     The clock should light up and visualize the time
    Enable the script to run at startup:
    Go edit the rc.local file
    sudo nano /etc/rc.local
    and add this line before the exit 0
    /bin/bash /home/clockPi/wordClock/run_clock.sh &
     It's all set
    You can reboot the pi and see what happens
    sudo reboot
View project log
  • 1
    Hardware
    This is basically a LED matrix, with a cardboard mask in front. I decided to go for a 12x12 LEDs, one every 2 cm, so in total 24x24 cm.
    - Draw a 12x12 grid in the center of the base board
    - Attach the LEDs at the midpoints in the grid, wire it up following the exposed pads in the LED strip
    - Insert the Raspberry pi and wire it up too
    - Add a power connector on the back, and wire the +5V to the raspberry pi and the LEDs
    - Build the plastic/foam separator to isolate each LED from the base to the front
    - Carve the cardboard in front with the letters
  • 2
    Software
    Follow the Software instructions post with the steps
View all instructions
