Lemon and lemonade
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 12/28/2025 at 03:390 Comments
The last log has shown that the decoder has low performance. The encoder though is quite rad. I could swap them to get the desired result but that would still be insufficient. However it would be good to apply the encoder iteratively to get even better error-spreading.
This means that the Hamming Maximisation circuit is not just in series with 116. NRZ FTW in the pipeline but integrated inside it. In fact the bit-flipping should be inside the feedback loop for greatest efficiency.
And the beauty here is that the H transform (?) does not need to be a bijection, or provided in reverse form, so the unit is unique, implemented in one instance in the circuit, possibly shared by the send and receive circuits. It could increase in complexity later...
However the study of the reverse transform informs us about some key characteristics. Those are not stellar but the iteration brings the required efficiency. It can still be increased by an output permutation, such that cyclic sequences are not too short.
Another transformation to consider is swapping gates in the maximiser, to reduce wire crossings. I know this will be taken care of by the P&R program but there is no harm in helping it.
