I have a first functional circuit in ASIC and I must write the Python code that tests the sea-of-xor.
There are 19 key values to test: 0 and the 18 single-bit-at-1 configurations.
Then throw a few "random" values for good measure, since the rest should be a linear combination of all the 18 single-bit cases, right ? And the all-ones case of course.
But then the results of some test vectors could become vectors themselves. So some VHDL later and we get
111111111111111111 101011111000110100 000000000000000000 000000000000000000 000000000000000001 110111011111011001 000000000000000010 110111011111011111 000000000000000100 110111101111011111 000000000000001000 110111101110011111 000000000000010000 010111100110110101 000000000000100000 110001101011001010 000000000001000000 000000011111111000 000000000010000000 101110111001000000 000000000100000000 111111000010100000 000000001000000000 111111011111111001 000000010000000000 111110111111111001 000000100000000000 111110111111110101 000001000000000000 001101111111010101 000010000000000000 000111100010110101 000100000000000000 110111000000100110 001000000000000000 111111000000101100 010000000000000000 100001001101110000 100000000000000000 000000011111111010 111111111000000000 011100010000010101 000000000111111111 110111101000100001 101010101010101010 100110111110100101 010101010101010101 001101000110010001 110111011111011001 011011011100100111 110001101011001010 000011011010101011 000000011111111010 110110111000100111 011011011100100111 101100110110001111 001101111111010101 111100010010000001 011011010110110101 011101101001011100 100100101001001010 110110010001101000 110110010001101000 101001010101001101 111100010010000001 001110001011100000 110110111000100111 101000101011111111 100110111110100101 101111000010110000 000011011010101011 100011000001110011 101000101011111111 110110010101011011 100011000001110011 101100010000011011 001110001011100000 101111110000110100
Now I must find again how Python encodes binary data.
It seems to work.
excepts that it outputs MSB first.
I consider making a subcircuit just to implement and test the Hammer18 in 3 modes: direct, encode and decode
result : it works well.
and the current circuit uses only 22% of the tile.
Routing stats
| Utilisation (%) | Wire length (um) |
| 21.265 | 17366 |
Cell usage by Category
| Category | Cells | Count |
| Fill | decap fill | 1742 |
| OR | xor2 or2 | 83 |
| Flip Flops | dfrbpq dfrbp sdfrbpq | 69 |
| Misc | dlygate4sd3 | 67 |
| Buffer | buf | 66 |
| Multiplexer | mux2 | 36 |
| Inverter | inv | 21 |
| Combo Logic | a22oi | 9 |
| NOR | nor4 | 4 |
| AND | and2 and4 | 2 |
357 total cells (excluding fill and tap cells)
The speed easily reaches 100MHz, can be pushed to 200MHz,
but the stats show that about half of the surface is DDFs, 1/4th is buffers/delays/fanouts, and 1/4 is logic gates...
Cell type report: Count Area
Fill cell 1742 20588.00
Buffer 3 21.77
Clock buffer 23 493.52
Timing Repair Buffer 107 1701.91
Inverter 9 48.99
Clock inverter 12 65.32
Sequential cell 69 3917.29
Multi-Input combinational cell 146 2104.70
Total 2111 28941.49now, that makes you think..
Yann Guidon / YGDES
