SU(3)
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 03/30/2025 at 16:330 Comments
Damnit, that ternary system needs more theory than I expected. I now have to use "higher math" to get things done.
More formally I have defined 2 operations on a ternary marker:
And I had found the fortunate identity :
ID = swap(swap) = swap(rot(swap(rot)))
Thus Rot-¹ = swap(rot(swap))  as in the 1st version, which worked with the first ternary version.
 Now I need to work that further so it can handle rot combined with swap. I can't have 2 rot because it's too long so I can't use ID = rot(rot(rot)), only 2 rot at most are possible (one in sender, the other in receiver).
It doesn't feel very right because rot^-1 = rot(rot) = 120 : the position of the 0 should be shifted by each rot operation.
___________________________________________________________
The "solution" looks like "yet another adder", but an unusual one : mod 3.
