mod3bis
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 03/30/2025 at 23:430 Comments
Oh so I messed with the Karnaugh map... Here's a proper set.
LSB:
MSB:
By chance there are a couple of common terms, /A/B and /C/D.
The "good" aspect is that 5 of the 7 X turn to 1s so 3 of the unexpected or forbidden cases turn to mark 11, which also increases the avalanche to the PEAC level.
In other words :
inputs:
inputs:
 A0 = D
 A1 = C
 B0 = B
 B1 = A
t1 := /B0./B1
t2 := /A0./A1
LSB := (A1.B1) | (t1.A0) | (t2.B0)
MSB := (B0.A0) | (t1.A1) | (t2.B1)
Note : t1 & t2 can be pushed before,
The circuit : this time I made extra efforts to check each input. The complexity increased a bit but latency is still the same as the last version so OK.
Time to rererereredo the VHDL.
And it's a success ! get the source code here.
 Number of PopC errors = 623472/1048576
 Number of type errors = 39204
A good number of invalid data get transformed to mark=11 and thus flagged as "type errors".
