Reversible PEAC scrambler
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 04/05/2025 at 02:380 Comments
I'm reworking the PEAC scrambler and the result is a single unit that does both scrambling and descrambling.
The only meaningful difference is that SumX is available immediately on Data_out, without waiting for the register Y. This affects the timing, a little.
Of course, during synthesis, the optimiser can reduce the complexity when the Co/Dec signal is a constant.
And if the unit's function alternates, the X/Y/C/D registers should be placed outside, such that the controlling FSM can select the appropriate values for each cycle.
The last detail to check is the D value that might have to be XORed depending on the function. It still has to be tested. Stay tuned.
Rebuilding the test suite already shows the trouble that the immediate availability of SumX creates : it skips a step at the encoding stage. This shifts the timing : Data_out must be sampled before sending the clock pulse. I added a one-clock delay in the wrapper but I'll change the testbench's behaviour...
The mark's half adder is another head-scratcher, with its value shifted to the next cycle. It seems now that it's better in the same logical layer, even though it could increase the critical datapath's length a little bit.
So this is the new diagram:
The C/D/X/Y registers are now taken outside and must be managed by a suitable wrapper.
