I know I need a better PEAC scrambler but I first want to establish a base, with which to compare later developments.
So I hooked the now validated GrayPar17 layer with the existing PEAC16x2 to see what would happen, and it's... interesting.
Disclaimer:
- C/D is now part of the "payload" but not processed by PEAC so some stats might be off by something or so.
- Input data comes from a LFSR, which might not be representative, but injects enough "noise" to help sampling the space.
Thing to check are
- the number of iterations required to (if ever) detect an error, plot the histogram of the latency, and find an eventual upper limit (to help in defining the protocol)
- see which lengths are harder to detect and where
Overall GrayPar17 does a pretty good job at filtering most events, and I could refine the rough stats from 69. spurious errors.
At first, I only check 1-bit flips. The upper limit of loop iterations is 30 though ideally it should be much shorter, but I want to see what happens.
Scan of all the 20 bit positions, 100K times:
~~~ Testing PEAC16+GrayPar17 w. error ~~~
burst length=1
index=0 Stage1: 50019 Stage2: 49981
index=1 Stage1:100000
index=2 Stage1: 33246 Stage2: 66754
index=3 Stage1: 50501 Stage2: 46343 Stage3: 3049 missed:107
index=4 Stage1:100000
index=5 Stage1: 33300 Stage2: 66700
index=6 Stage1: 49853 Stage2: 43765 Stage3: 6377 missed:5
index=7 Stage1:100000
index=8 Stage1: 33241 Stage2: 66759
index=9 Stage1: 50003 Stage2: 49997
index=10 Stage1:100000
index=11 Stage1: 33407 Stage2: 66593
index=12 Stage1: 50307 Stage2: 46534 Stage3: 3042 missed:117
index=13 Stage1:100000
index=14 Stage1: 33384 Stage2: 66616
index=15 Stage1: 49821 Stage2: 43858 Stage3: 6316 missed:5
index=16 Stage1:100000
index=17 Stage1: 33221 Stage2: 66779
index=18 Stage1: 50043 Stage2: 37403 Stage3:12552 missed:2
index=19 Stage1: 66702 Stage2: 33298
- Stage 1 is detection out of SUB3, it should average 50% detection rate.
- Stage 2 is immediate detection by comparison of the marker: most of the rest but could miss 1/4 (1/8)
- Stage 3 is when the marker is not rejected immediately, but after a number of iterations.
- Missed : PEAC has not bubbled the error to the carry in 30 cycles...
Offending indices are 3 and 12 (1/1000th chance of missing a single bit flip), followed by 6, 15 and 18 (< 1/10000).
OTOH indices 1, 4, 7, 10, 13, 16 are spot on. But that's only 1 in 3 positions.
The other positions are caught immediately at stage 2.
What is at indices 3 and 12 to be so sensitive ? and why is 9 not affected ?
- 2-9-16 are the summed output of the parities and the markers, these bits do not appear fragile.
- 3-6-12-15-18 all belong to the middle V/P2
- in particular 3 and 12 are closely related, neighbours in the parity circuits. They share the input/output bit 6 (and 2 and 12).
- paradoxically, the very great 1-4-7-10-13-16 signals are related to P3, which is combined by a longer chain in the ADD3/SUB3 units.
- the remaining bits 5-8-11-14-17 are related to P1/S0 by a simple XOR.
So the ADD3/SUB3 system might not be ideal, end-around carry could become necessary.
I also want to see how long it takes for an error beyond stage 2 to be detected.
Pushing to 50 loops, I get:
1 : 5830 - *****************************************************************************
2 : 7574 - ****************************************************************************************************
3 : 4492 - ************************************************************
4 : 2897 - ***************************************
5 : 2249 - ******************************
6 : 1587 - *********************
7 : 1359 - ******************
8 : 998 - **************
9 : 756 - **********
10 : 599 - ********
11 : 559 - ********
12 : 447 - ******
13 : 371 - *****
14 : 317 - *****
15 : 171 - ***
16 : 209 - ***
17 : 189 - ***
18 : 155 - ***
19 : 97 - **
20 : 104 - **
21 : 129 - **
22 : 71 - *
23 : 46 - *
24 : 24 - *
25 : 46 - *
26 : 52 - *
27 : 15 - *
28 : 18 - *
29 : 23 - *
30 : 31 - *
31 : 18 - *
32 : 4 - *
33 : 9 - *
34 : 14 - *
35 : 12 - *
36 : 17 - *
37 : 12 - *
38 : 0 -
39 : 12 - *
40 : 11 - *
41 : 10 - *
42 : 0 -
43 : 10 - *
44 : 0 -
45 : 6 - *
46 : 4 - *
47 : 6 - *
The 10 first loops catch 28341 errors already, or 86%, but what is an acceptable error rate ?
Convergence is a problem because pushing to 20 loops catches 30960, or 98%, but it is enough yet, and can the protocol accommodate such a long delay ? Particularly since, with such a long latency, other errors could pop up and "cancel" the first flip.
Hopefully, the convergence should be solved by an more appropriate PEAC structure.
Yann Guidon / YGDES
