C/D in the middle
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 11/10/2025 at 07:540 Comments
There is an excellent reason to place the "pseudoparity" bit at the gPEAC's MSB: its set/reset rate is 48% so it couldn't encode all numbers, unlike de C or D bit of the binary PEAC.
However the C/D flag's position is arbitrary. And being grouped/bundled with the parity might not be the best strategy. So how about we put it in the middle ? At bit position 8 for example, it has better chances to trigger an error earlier than if it had to wait for the carry chain to avalanche to the MSB.
It's just a matter of re-wiring a bit. It doesn't change the error detection rate but it should affect its curve's shape, a bit...
