Software - OneWire slave lib
06/10/2017 at 21:25 • 0 commentsI think I just foud what I needed!
https://github.com/M-o-a-T/owslave
This is code for OneWire slave, working for the Attiny13.
The blink test !
06/10/2017 at 08:29 • 0 commentsSome tests in low voltage confirm that the hardware is ok !
Here is the setup with 1 switch and a 12V car light bulb.
For now, the firmware just blink the relay. The next big step is to implement the OneWire slave and the current measurement.
PCB ready for assembly !
03/27/2017 at 18:58 • 0 commentsA surprise in the mailbox today !
80 PCBs ! still waiting for some caps ans resistors...
It's super small !
PCB Order placed
03/06/2017 at 21:59 • 0 commentsPCB have been ordered, 17USD for 80pcs! (At https://www.seeedstudio.com/fusion_pcb.html )
8 boards by PCB, 10 PCB.
Some change has been made:
- Change for a bigger 5V regulator (100ma from 12 to 5)
- Add milling slot for insulation
- Open Source Hardware logo
Github repository is up to date : https://github.com/thomasfla/onewire-smart-switch
Thomas Flayols
