Variant V1:
The device can be mounted as an add-on panel to any other device panel of at least 110x74 mm size. Soldering side of the device requires 5mm and the components side needs 22 mm of free height. It is also possible to mount the device into Fibox Euronord housing of series 1212xx with IP67 protection, the fixing points are dimensioned accordingly. In this case sandwich structure may be constructed with the carrying panel; the fixing points are available on the panel of the energy module. These should reasonably be equipped with 30 mm long M3 metal spacers with external and internal threads, and the other panel can be fixed to them. Connection can also be solved with high row of pins from CN2 and CN5 connections, either in a releasable or fixed soldered way. The Fibox Euronord 1212xx series is available in different heights: 65-75-95-105 mm. The solar cable can be connected to the house through a simple cable gland.
Variant V2:
The device can be put on DIN rail (35 mm) with a snap lock. Placement is possible in any DIN rail electric box or separately on the wall. In the latter case only a piece of 35 mm DIN rail has to be mounted on the wall. Electric outlet is made through pcb terminal blocks, which are mechanically integrated in the device housing. The connections can receive cables of maximum 1,5mm2.
Size: 110 x 75 x 45 mm Weight: 320 g
Gabor Futo
Dan Julio
Darryl Norman
