Low Voltage UPS System with SolarUPS devices
03/27/2019 at 07:35 • 0 commentsLow Voltage UPS System with SolarUPS devices. Small solar panel or AC/DC power supply input, 5-12Ah Li-ion or SLA battery capacity, 3.3-12V / 500-2500mA DC output.
SolarUPS is CE certified
10/18/2017 at 11:56 • 0 comments![]()
DC Output Current
10/18/2017 at 11:52 • 0 commentsDC output current depends on the battery charge and selected output voltage:
Battery parameters
10/18/2017 at 11:48 • 0 commentsThe SolarUPS device is an industrial grade solution, the Li-ion battery has a wide temperature range and extended lifetime type (as with new electric cars).
( battery pack: 2 x 4400mAh Li-ion)
Solar Power for Arduino!
08/29/2017 at 06:12 • 0 commentsSolar Power for Arduino!
Simple solar uninterruptible power supply for Arduino projects.![]()
Solar Power for Raspberry Pi!
08/29/2017 at 06:11 • 0 commentsSolar Power for Raspberry Pi!
Simple solar uninterruptible power supply for Raspberry projects.![]()
Gabor Futo
