ROM Disassembly - Cefucom-21
Peering into the soul of this obscure machine
Reference to an obscure early 80's era Computer Aided Instruction machine came across my desk, and there were ROM dumps, so as they say: "have ROM dumps; will disassemble" (well, if "they" is "me", at least...).
I suspect that the resulting disassembly is less interesting than the voyage of discovery I'm logging here. "It's not the destination, it's the journey." They say that, too, though this time "they" is not "me".
Overtly, this project provides a disassembly listing of the Cefucom-21 system, which is a vintage Computer-Aided lnstruction device (c. 1982) for teaching English to native Japanese speakers.
Who would care about such?  Maybe no one, unless you have one of these rarities and want to hack.
Less overtly, this project is a chronicle of of my activities and discoveries along the way, which is useful for me to record, but I though could be interesting to someone else to see the process, so I decided to publish it here instead of in my usual private journal.
It will be a little bit of a challenge in that I do not have the hardware, nor schematics.  Just the ROM dumps.  Well, and some photos of the boards, which are immensely helpful.  And also now knowledge that this system is based on a then-existing general-purpose system -- the Sanyo PHC-25.  That system itself is pretty obscure as it seems to have done poorly in the marketplace.
But the fun is in figuring things out, so those handicaps add something....
  • 20241114 - Virtual Machine Summary
    ziggurat298 hours ago 0 comments
    Yesterday I mentioned this apparent 'virtual machine' embedded in the Cefucom product, and I spent some time figuring how the it do.  The machine workings are pretty clear now, and I have done 66 of the opcodes (10 more to figure out).  Here's the scoop so far:
    Overview
    *  basic unit of execution is a 'block'
    *  block structure is:
      *  opcode
      *  parameters...  Number of parameters is opcode-specific.  So a block is between 1 and 7 bytes.
    *  a 'program' is a series of blocks
    *  rst 8 is the 'primitive block executive'.  It is not typically used directly.
    *  rst 10 is the 'sequenced block executive', and is the primary way of executing 'programs'
    *  is BIG-ENDIAN
    *  has absolute addresses
    *  indices are 1-relative
    *  has various functional groups:
      *  load/store; 8 and 16 bit, references and constants
      *  memset/memcpy
      *  arithmetic; addition/subtraction, usually accumulator form (e.g. *parm1 += *param2)
      *  bitwise; and, or, xor (note, no 'not', though I suppose you can synthesize that from xor)
      *  shift
      *  goto
      *  computed goto (well, 'indexed'; the computation would be done separately)
      *  if (and if-not)
      *  next
      *  'usr' (call out to an assembly routine)
      *  'run' (another program)
      *  some Cefucom specific opcodes; probably added by the company
    other notable aspects
    *  The C register is used to store flags, where appropriate.  80h = carry, 1 = non-zero/no-carry, 0 = zero.  The C register is actively preserved between block execution.
    *  A couple instrucstion place the result in B or DE, but these are not preserved between blocks.  (I need to look more into this when I find a program that invokes them; and maybe there are no instances of such.)
    *  the RST 10 implementation realizes a few more outside of the dispatch table:
      *  7F - NOP
      *  7E - exit on no-carry
      *  7D - exit on carry
      *  7C - exit on non-zero (or carry)
      *  7B - exit on zero
    *  the implementation speculatively loads param1 into HL and param2 into DE, which is useful for most instructions, but some do have less parameters (e.g. END).  This is a potential out-of-bounds read, but will not cause problems on this hardware.
    *  there are two opcodes 62h and 63h which have little-endian parameters param1 and param2, while param3 is big-endian.  I think this is a bug, though it might originate from a detail of their build process.
    *  opcode 43 is also little-endian, which runs a rst 10 program.  This is interesting because there is already opcode 3e that does the same thing with a big-endian program pointer, so there must have been felt a special need.
    The remaining opcodes deal with Cefucom structures which I do not yet understand, so I might put those off for the moment in the interest of making progress.
    One vexing thing has been some functions that do some stack manipulation such that the execution is no longer linear.  I figured out some of those, like the ones that have a dispatch table that follows a call.  But there are some others that have more convoluted shenanigans.  I marked those as 'witchcraft' so that I can find them more easily when I come back to them.  Perhaps now is the time to look into this witchcraft.
  • 20241113 - An Embedded P-Code-esque Virtual Machine?
    ziggurat292 days ago 0 comments
    As mentioned before there are a lot of tables, and even a couple of tables of tables.  Some are lists of 'described text' (having a header indicating position), some are indexed dispatch tables, some are double-dispatch, and the others are presently unknown.
    I had previously thought the table-of-tables form was a double-dispatch mechanism, but it's not.  Rather it's a list
    Often they are processed by RST 10, which delegates processing of the elements to RST 8.  The elements are variably-sized blocks.  They seem to have the structure:
    uint8_t     fxn;
    uint16le_t  param1;
    uint16le_t  param2;
    ...         payload;
    (I am coining the term 'uint16le_t' because I have found many places that are big-endian! So elsewhere I use 'uint16be_t' for that.)
    Often the blocks are short, like this:
    7817 62      byte_7817:db 62h
    7818 95 7A   dw unk_7A95
    781A 11 00   dw 11h
    781C 00      db 0
    but others can be quite long.  I originally thought param1 is a pointer, and params is a length, because the RST 8 code that processed them immediately loads param1 into HL and param2 into DE.  Indeed sometimes those are used as pointers and lengths, but in other cases they are not.  But for starters I look at the ones at off_7803, which is a list of these things which have just one element in them, and seem to follow the (ptr,length) assumption.  The trailing zero is interesting.  All the ptrs and lengths worked out sanely when updating the the disassembly.
    These blocks are ultimately processed by RST 10.  This is a block sequencer, feeding individual blocks to RST 8 (which expects the block pointer in IX).  A null function code terminates processing, so that explains the trailing 'db 0' above.  So there is no explicit payload length of a block; it depends on function code.
    RST 8 dispatches servicing through dispatch_4002, which has 128(!) entries.  I went through and labelled each of them like 'fxn00'.  Many of them are apparently unimplemented as their slot directs to 'fxn00', which was found to be used as the block sequence terminator.  It does have an implementation, though, which is to back up IX by 4.  This is interesting because fxn00 will not be dispatched by RST 10, but it would for the ostensibly unimplemented function codes.  Turns out that RST is optimistically loading param1 and param2 and incrementing IX just past.  So the IX-=4 is to undo that optimistic loading and continue at the byte following the unimplemented function code.  So 'ignore unimplemented function code'.
    In the end, there are 76 implemented and 52 unimplemented functions.
    After labelling, I looked at fxn62h, since that was the the code used in the blocks above.  The implementation boggled my mind a bit.  It did some sort of queueing into c200, which is structured as 32 8-byte entries.  A gave up with that and scrolled through the nearby disassembly casually and found fxn63 just below it, that also did something similar with c200, and then invoked my buddy RST 10 -- the 'block list dispatcher'.  So if fxn62 puts it in, and fxn63 takes it out and processes it, this seems evocative of a 'load' and 'run' functionality.  Anyway, there was still too many unknowns so I started to look for smaller fish to fry.
    Scrolling through I found some shorter ones that I could comprehend, and coincidentally these tended to be the smaller numbered function codes.  The first one I found was:
    43FD  ; XXX 3f: dispatch to param1 (no param2)
    43FD  fxn3f_43FD:
    43FD DD 2B  dec     ix  ; (no param2)
    43FF DD 2B  dec     ix
    4401 E9     jp  (hl)    ; thunk over
    So this would run arbitrary external code.
    Another is a conditional 'goto' of sorts, where the block processing is directed to another place (hopefully within the list!) if --*((uint8_t*)param2) != 0:
    43D3  ; XXX 3c: goto block @ param1
    43D3  fxn3c_43D3:
    43D3 EB     ex  de, hl
    43D4 35     dec     (hl)
    43D5 28 03  jr  z, leave_43DA   ; leave if --*((uint8_t*)param2) == 0
    43D7 D5     push    de
    43D8 DD...
  • 20241111 - Catching Up and Publishing Work
    Last week's PCU push put me further behind in posting, so I caught up those log entries.
    Also, I don't know why I didn't already, but I put the listing in a github so others can check it out if they are curious.  There's a link in the project's 'link' section, and also here if you happen to be reading this entry:
    https://github.com/ziggurat29/cefucom-21.git
    It's a pity I didn't start this at the beginning so that I could see the history of this past 3 week's work, but oh well.  I was moving fast then.  Still am.
    Now that all the puzzle pieces are on the table, it's time to see what picture emerges when solved.  There's no depiction on the packaging. ;)
  • 20241110 -- PPI (8255) Catalogue
    Today I went though all the references to the 3 Programmable Peripheral Interface (PPI; 8255) devices.  To my relief they are configured once and stay that way.  Also, they are all set to be garden-variety gpio -- no special modes.
    8255 Summary:
    8255a:
    Port A: in
    Port B: out
    Port C: in
    8255b:
    Port A: out
    Port B: out
    Port C (upper): out
    Port C (lower): in
    8255c:
    Port A: in
    Port B: in
    Port C: out
    Mostly I don't know what these do, though, because I have no schematic.  It's worth noting that my nomenclature of "8255a" and "CTCa" is purely made up.  I don't know what actual device on the board these are associated with.  Otherwise I'd use the parts marking on the board.  If I ever find out, then I'll update the info.  This did send me on a side activity of going through the screen shot and collecting all the parts.  (Well, just the IC's.)  So I made a BOM for future reference.  The BOM occasionally gives me some ideas; e.g. there are two 7474's on board.  Maybe clock dividers?  And if someone has a physical board and is willing, I can be specific about requests to buzz out specific pins.  (Especially the address decoders to the various chip selects would be handy!)
    I can say that 8255b-a is unused, and that the unusual 8255b-c is used for the bit-bang serial, and possibly RTS/CTS.
    Watchdog?
    In the course of this, I found a bit which is polled periodically, and will reset a down counter.  If the counter reaches zero, a request for reboot is flagged.  This check is registered in the CTCb2 task list (entry 1).
    0D7D  isrCTCb2task01_watchdog_D7D:
    D7D DB 69      in  a, (69h)              ; 8255c-b; checking b6
    0D7F 47        ld  b, a
    0D80 DB 69     in  a, (69h)              ; 8255c-b; checking b6
    0D82 B8        cp  b
    0D83 20 14     jr  nz, resetWatchdog_D99 ; transitioned during subsequent reads; lets try again
    0D85 CB 77     bit     6, a
    0D87 20 10     jr  nz, resetWatchdog_D99 ; b6 = 1 == system ready?
    0D89 3A 69 C0  ld  a, (byte_C069)        ; XXX a watchdog timer; initted to 5 on 69h b6 set (system ready)
    0D8C 3D        dec     a
    0D8D 32 69 C0  ld  (byte_C069), a        ; XXX a watchdog timer; initted to 5 on 69h b6 set (system ready)
    0D90 20 0C     jr  nz, nullsub_10        ; leave
    0D92 3E FF     ld  a, 0FFh
    0D94 32 68 C0  ld  (byte_C068), a        ; XXX flag causing warm boot (or maybe sleep) in main task 00
    0D97 18 05     jr  nullsub_10
    0D99         resetWatchdog_D99:
    0D99 3E 05     ld  a, 5                  ; give it 5 chances to come back
    0D9B 32 69 C0  ld  (byte_C069), a        ; XXX a watchdog timer; initted to 5 on 69h b6 set (system ready)
    0D9E         nullsub_10:
    0D9E C9        ret
    I'm calling this a 'watchdog' for now, but it might actually be something else that isn't supposed to stay low for too long.  Maybe a sensor of some sort.
    Ring Counter?
    Maybe the most interesting find was three bits that are configured in what appears to be a ring counter:
    5D44         sub_5D44:
    5D44 3A 02 81  ld  a, (byte_8102)
    5D47 32 03 81  ld  (byte_8103), a
    5D4A 21 B0 80  ld  hl, byte_80B0
    5D4D CB 96     res     2, (hl)             ; clear
    5D4F CB 8E     res     1, (hl)
    5D51 CB 86     res     0, (hl)
    5D53 3D        dec     a
    5D54 28 07     jr  z, was0_5D5D
    5D56 3D        dec     a
    5D57 28 07     jr  z, was1_5D60
    5D59 3D        dec     a
    5D5A 28 07     jr  z, was2_5D63
    5D5C C9        ret
    5D5D        was0_5D5D:
    5D5D CB CE     set     1, (hl)
    5D5F C9        ret
    5D60        was1_5D60:
    5D60 CB D6     set     2, (hl)
    5D62 C9        ret
    5D63        was2_5D63:
    5D63 CB C6     set     0, (hl)
    5D65 C9        ret
    and later:
    047D F3        di                  ; critical section
    047E 3A B0 80  ld  a, (byte_80B0)  ; XXX a bitfield; also goes out 8255b-b
    0481 E6 07     and     7           ; just the lower 3 bits
    0483 32 B0 80  ld  (byte_80B0), a  ; XXX a bitfield; also goes out 8255b-b
    0486 FB        ei                  ; end critical section
    0487 D3 65     out     (65h), a    ; 8255b-b
    A ring counter is a bit peculiar and in this product maybe drives a 4-wire 3-phase stepper motor.  Such a motor might be useful for advancing the paper roll display.
  • 20241109 -- Tables, and Tables of Tables
    There's still a fair amount of unexplored data and code.  Can't say much for data, but code you can figure out where functions demarcate in many cases just by looking for the C9 that is the RET that often punctuates a function end.  I found several 'orphan' functions this way.
    As a new tack, I searched the binary for the orphaned function's address.  Ostensibly to find a call site, but many times I found it in a list of addresses that mapped to other orphaned functions.  So I had found some dispatch tables.  Oftentimes is was easy to work backwards from such to find the start of the function table because it would abut some code ending.  Then I could do a similar address search to find the code that dispatches through the table.
    It was a bit tedious, but there are presently 42 such dispatch tables currently found!  And just for fun, it turns out that there are dispatch tables of dispatch tables in some cases!  There is a huge table of 128 entries at 4002h, a double-dispatch table at 2DA6 (with associated paramters table at 2DE0) and another double-dispatch table at 2200.
    With that many dispatch tables, this surely is some state machine design.  To think I was daunted by the one in ROM 4!  This is proportionately larger.  But who knows, this might be a gift as it might make the intent clearer.
    Bloopers
    Some amusing treats were nullsubs that have a subsequent jump to the nullsub.  (The code in the subsequent jump is not referenced anywhere.)
    3E9C  nullsub_4:
    3E9C C9        ret
    3E9D C3 9C 3E  jp      nullsub_4
    or
    3EA8  nullsub_5:
    3EA8 C9        ret
    3EA9 C3 A8 3E  jp      nullsub_5
     And a dispatch table of jump addresses that ends with a ret; lol.
    40FC 9E 41  dw sub_419E    ; XXX IX -= 4
    40FE 9E 41  dw sub_419E    ; XXX IX -= 4
    4100 9E 41  dw sub_419E    ; XXX IX -= 4
    4102 C9     ret
    My personal favorite:
    0475 18 00  jr  loc_477  ; well let's jump right on that!
    0477      loc_477:
    I think more symptoms of machine generated code.
    It took a day, but it got me to my desired 100% code coverage milestone.  Now that I have the puzzle pieces, it's time to see what picture emerges.
  • 20241108 -- PCU; RSTs and Rendering and Tasks and Serial
    ziggurat293 days ago 0 comments
    Desultorily rummaging through the code...
    RSTs
    There are only a few RSTs implemented in this unit.  Some are covered with FF and so don't do anything (well, they'll reboot since FF is coincidentally 'RST 0').
    RST 0 starts the party with 'ld  sp, C800h' and 'jp  boot_100'.  Seems OK, except boot_100 immediately changes it's mind to 'ld  sp, C7ffh'; lol.  Incidentally c800 is ostensibly more sane since SP is pre-decrement.  So C7ffh wastes the last byte.  But this is a fun system.
    RST 8, 10, and 18 do something.  RST 20, 28, 30, and 38 are in FF padding.  That padding continues out to the NMI 66h which I already describe it's special-ness.  It is immediately followed by one of these:
    0082  nullsub_7:
    0082 C9  ret
    "One of these" because there are nearly 40 such empty functions throughout the code.  So surely there's one within a relative jump range if you need it!  Joking aside, this is giving me the vibe that at least some of this code is machine-generated -- i.e. compiled or some other generation tool.  It was the 80s.  Throwing out redundant code is the linker's job, and there were business selling fancy linkers that had the smarts to do that.  Phar Lap is one that comes to mind.  I haven't discerned an obvious calling convention, though.
    RST 18 is the easiest to understand.  I simply vectors to an instruction indexed by A, 0-4.
    Function 01 was the first easiest as I was able to use my recent experience with the RTC to see that it was reading the clock and updating the values in RAM as BCD.  It confused me for a moment at the end where it OR'd all the values on top of each other and then masked that with 0f and conditionally invoked sub_DF9, until I realized that it was just checking for midnight.  So sub_DF9 does things at midnight.  It's only checking hours and minutes, so this needs to be invoked at least once a minute or it will miss it.  Also, it needs to be invoked not more than once a minute unless the midnight tasks are idempotent.
    RST 8 and 10 are more involved.  They operate on blocks of data.  The blocks have the form:
    00  code    8-bit
    01  param1  16-bit
    03  param2  16-bit
    04  ... data
    RST 8 expects the block to be referenced through IX
    RST 10 does a little more, expecting a sequence of blocks in HL, and then dispatching them via RST 8.
    What is amusing is that most of the code does not invoke these functions via the RST instruction.  Rather, they make the traditional 3-byte call to the underlying implementation.  There are no invocations of RST 8, and only one of RST 10.  All the invocations of rst 8 are direct (OK, there's only 3) and 24 direct invocations of rst 10.  So why bother?  Again, it seems to be more likely some machine generated code -- humans don't code this way.
    Tasks
    [Nigel] made a little headway getting past the memory test failure, but is stuck in a new loop.  His instruction trace ended up looping around here:
    01FC 3E C0     ld      a, 0C0h        ; IM2 vector base is C000h
    01FE ED 47     ld      i, a
    0200 ED 5E     im      2
    0202 FB        ei
    0203         again_203:
    0203 AF          xor     a
    0204 32 62 C0  ld      (byte_C062), a  ; XXX index into function table @ C040
    0207         next_207:
    0207 3A 62 C0        ld      a, (byte_C062)      ; XXX index into function table @ C040
    020A 07        rlca
    020B 06 00     ld      b, 0
    020D 4F        ld      c, a
    020E 21 40 C0  ld      hl, word_C040  ; XXX an array of 16 fxnptrs indexed by C062
    ... stuff
    022E 3C        inc     a
    022F FE 08     cp      8
    0231 28 D0     jr      z, again_203
    0233 32 62 C0  ld      (byte_C062), a  ; XXX index into function table @ C040
    0236 18 CF     jr      next_207
    Turns out this is exactly where it should be.  This is the main() loop!  What it does is whizz through a list of function pointers, invoking them, and then repeating that forever.
    The first task is mainTask00_default_2C3, and that is the one that check for the 'do warm boot' flag set by the NMI that we looked at yesterday!
    A curiousity is that there is room for 16 tasks, but only ever...
  • 20241107 -- Back to PCU Grindstone
    Reflecting on yesterday's experience with ROM 4, I'm a little daunted by what lays ahead.  That was a 2 KiB ROM.  This is a 32 KiB ROM, so 16 x as much to cover.  At the same time, the understandings I got from ROM 4 might provide context that speeds things along.
    The PIO A is configured much like on the MCU2, with differences in bit 7 and 6.  On the MCU2 b7 is the interrupt in, and b6 is unused.  On the PCU they are both outputs.  B7 does something.  B6 seems unused so far.
    PIO A does not provide an interrupt source as it does on MCU2, but there are plenty of timers, and in particular CTCb0 is configured free running. It prescales by 256 and has a time constant of 3fh, so that would imply a total division of 16384.  I don't know its clock source.  If it was the 4 MHz system clock, then that would be 244 per second, and if that were externally prescaled by 4, then that would be 61 per second.  Again, I don't know if any of that is the case.
    What I did negatively confirm is that there seems to be no systick as with the other board.  There is a counter that is incremented, but it is 8 bits and it saturates rather than rolling over.
    I was eager to find such a tick, because my assumption was that PIO Port B would be serviced similarly here -- and it is, except for the timeout.  Had it been the case I might have been able to work out what the clock rate likely is.  Oh well.
    The PIO B ISR is freaky.  It starts off sane:
    3D48  isrPIOb_3D48:
    3D48 FB      ei                  ; allow nesting
    3D49 F5      push    af
    3D4A C5      push    bc
    3D4B D5      push    de
    3D4C E5      push    hl
    3D4D CD 56 3D    call    impl_isrPIOb_3D56       ; XXX PIO B isr implementation; invoked after saving all regs
    3D50 E1      pop     hl
    3D51 D1      pop     de
    3D52 C1      pop     bc
    3D53 F1      pop     af
    3D54 ED 4D   reti
    and then things get weird:
    3D56  impl_isrPIOb_3D56:
    3D56 4F        ld  c, a         ; XXX freaky; where was A set? non-isr code? 'expect'?
    3D57 DB 10     in  a, (10h)     ; XXX PIO A data; ostensibly 'state' (though we aren't masking off high bits for some reason)
    3D59 B9        cp  c
    3D5A 20 FA     jr  nz, impl_isrPIOb_3D56  ; loop, there it is!
    3D5C E6 07     and     7        ; mask only b2,b1,b0 ('state')
    3D5E C2 68 3E  jp  nz, sub_3E68
    So, two things:
    1. a spin-wait in an ISR for anything tweaks my spidey-sense
    2. we are checking for a value that is specified in A, but we never explicitly set A ourselves.  A will be whatever it was in the pre-interrupt environment.  All the more curious because Port B I/O is not synchronous to this system.
    And I guess a minor thing is that we didn't mask off bits 7 and 6.
    This is a head-scratcher.  I'll have to come back to it later.  (maybe some weird coordination with non-isr code:  "wait for this and let me know".  I'll keep an eye out for that pattern.)
    Another treat:
    7FA9 3E 4F  ld      a, 4Fh
    7FAB D3 E3  out     (0E3h), a       ; XXX set PIO B mode 1 (input)
    7FAD 3E 87  ld      a, 87h
    7FAF D3 E2  out     (0E2h), a       ; XXX wut? it's now an input port, so what is write doing?
    Since [Nigel] was concerned about the port 30/38/39 stuff I took a little look at that.  On cold boot, port 38h is read, and then jumps into the warm boot routine which immediately writes it out to port 39h.  Warm boot ("boot_100") may be entered in other ways, and those ways a value left over from a previous write to both 30h and 38h is the one that is written to 39h.
    And that is the end of the story for those ports.  They don't affect code flow in direct way (conceivably they might indirectly by causing some unknown hardware to do something different).  So looking into what the 'leftover value' is that comes in on the warm boot path led me to some RTC stuff.
    02C3  sub_2C3:
    02C3 3A 6D C0  ld      a, (byte_C06D)   ; a flag set in NMI
    02C6 B7        or      a
    02C7 20 0D     jr      nz, loc_2D6      ; horror
    02C9 3A 68 C0  ld      a, (byte_C068)   ; another flag that could cause us to reboot
    02CC B7        or      a
    02CD C8        ret     z
    02CE F3        di
    02CF CD A2 0E  call    sub_EA2      ; XXX RTC alarm stuff; leaves something in A
    02D2 D3 38     out     (38h), a     ; hmm!
    02D4 D3 30...
  • 20241106 -- ROM 4
    I spent yesterday disassembling ROM 4 of the MCU2 board.  I got to 100% code coverage of that one.  That doesn't mean 100% understanding, it just means all the jigsaw puzzle pieces are now on the table.
    It was interesting.  There are a lot of table-dispatched functions.
    Dispatch Magic
    I found some code which seems to be in a spin-wait for something to come into 8000h.
    7874  loc_7874:
    7874 E1           pop     hl              ; discard the return address
    7875 ED 73 CE FF  ld      (word_FFCE), sp ; XXX stores SP during some Cefucom ROM4 stuff
    7879  loop_7879:
    7879 CD B9 78     call    sub_78B9        ; XXX some stuff with keys (as in buttons)
    787C 2A C3 FF     ld      hl, (word_FFC3) ; XXX Cefu; a pointer into buffer @8000h
    787F 11 00 80     ld      de, unk_8000
    7882 B7           or      a
    7883 ED 52        sbc     hl, de
    7885 28 F2        jr      z, loop_7879    ; XXX nothing 'received'; spin
    7887 21 00 00     ld      hl, 0
    788A 22 C5 FF     ld      (word_FFC5), hl
    788D CD E3 78     call    sub_78E3        ; XXX messes with DE, which will be a synthetic return address
    7890 CD 7F 79     call    sub_797F
    7893 01 99 78     ld      bc, sub_7899
    7896 C5           push    bc              ; queue sub_7899 on the stack
    7897 D5           push    de              ; queue the call sub_78E3 computed
    7898 C9           ret                     ; (not really returning from here since we queued the above two)
    And there is magicry at the end.
    The code infers the availability of data by the difference between the start of buffer and end of buffer, so that end of buffer pointer must be atomically updated.  Cross referencing word_FFC5 I find that is indeed happening:
    7899  sub_7899:
    7899 F3           di          ; critical section around these pointer updates
    789A 2A C5 FF     ld  hl, (word_FFC5) ; XXX Cefu; an OFFSET into buffer @8000 while building
    ... move block into position at 8000h and computes end in DE and other stuff
    78B2 ED 53 C3 FF  ld  (word_FFC3), de ; XXX Cefu; an end pointer into buffer @8000h
    78B6 FB           ei          ; end critical section
    so word_FFC5 seems to be used while transferring the block, and when it is completed then word_FFC3 is atomically updated with the final value.
    The magicry at the end depends on sub_78E3 leaving a return address in DE, which eventually gets pushed to the stack prior to the ret, effectively synthesizing 'jp (de)'.
    78E3   ; XXX lookup dispatch info
    78E3   sub_78E3:
    78E3 21 00 80     ld      hl, unk_8000
    78E6 E5           push    hl
    78E7 7E           ld      a, (hl)         ; get the code from buffer
    78E8 ED 4B 1C 00  ld      bc, (off_1B+1)  ; XXX freaky as it is in the middle of a constant; val c7e0. bug?
    78EC 21 0B 79     ld      hl, dispatchByCode_790B ; XXX dispatch 29 entries/116 by: (code, C, addr)
    78EF   loop_78EF:
    78EF ED A1        cpi
    78F1 28 08        jr      z, leave_78FB   ; found it
    78F3 E2 05 79     jp      po, loc_7905    ; finished; but not found
    78F6 23           inc     hl              ; (HL already +1, so we only need +3 to get to next)
    78F7 23           inc     hl
    78F8 23           inc     hl
    78F9 18 F4        jr      loop_78EF
    78FB   leave_78FB:
    78FB 4E           ld      c, (hl)
    78FC 06 00        ld      b, 0
    78FE 23           inc     hl
    78FF 5E           ld      e, (hl)
    7900 23           inc     hl
    7901 56           ld      d, (hl)
    7902 E1           pop     hl              ; (which will be 8000h)
    7903 23           inc     hl
    7904 C9           ret
    7905   loc_7905:
    7905 23           inc     hl
    7906 23           inc     hl
    7907 23           inc     hl
    7908 23           inc     hl
    7909 18 F0        jr      leave_78FB
    The sub_78E3 basically looks up the servicing address from the code that is at the start of the block, and returns an additional associated parameter in C.  Here's the first entry:
    790B 21  dispatchByCode_790B:db 21h  ; code to match @8000h
    790C 05     db 5          ; XXX goes in C
    790D A6 79  dw sub_79A6   ; XXX goes in DE (and becomes a call address)
    That table has 29 entries.
    "State"
    Rummaging through the references to PIO A code, there were sections like this:
    7E96  sub_7E96:
    7E96 3E 02     ld      a, 2
    7E98 32 E4 FF  ld      (byte_FFE4), a
    7E9B 3E 10     ld      a, 10h
    7E9D D3 E0     out     (0E0h), a
    7E9F 3A EA FF  ld      a, (byte_FFE8+2)
    7EA2 D3 E2     out     (0E2h), a       ; PIO B data out
    7EA4 C9        ret
    Knowing that PIO A b2,1,0 are inputs, and that b5,4,3 are outputs, it occurred to me that those might be bitfields of a 3-bit number.  One expressed from MCU2...
  • 20241106 -- ROM 4
    Dispatch Magic
    7874  loc_7874:
    7879  loop_7879:
    7882 B7           or      a
    7899  sub_7899:
    78E3   sub_78E3:
    78E6 E5           push    hl
    78EF   loop_78EF:
    78EF ED A1        cpi
    78F7 23           inc     hl
    78F8 23           inc     hl
    78FB   leave_78FB:
    78FB 4E           ld      c, (hl)
    78FC 06 00        ld      b, 0
    78FE 23           inc     hl
    78FF 5E           ld      e, (hl)
    7900 23           inc     hl
    7901 56           ld      d, (hl)
    7903 23           inc     hl
    7904 C9           ret
    7905   loc_7905:
    7905 23           inc     hl
    7906 23           inc     hl
    7907 23           inc     hl
    7908 23           inc     hl
    "State"
    7E96  sub_7E96:
    7E96 3E 02     ld      a, 2
    7EA4 C9        ret
  • 20241105 -- PCU Initial Results, Serial, and on to ROM 4
    I delivered my initial results to [Nigel].  We are in agreement that the PIO added to the 'main' (MCU2) board is the thing that does the interboard communications.
    On the MCU board I had observed that PIO Port A was the datasheet calls 'control' mode, which means 'general purpose I/O'.  But PIO Port B is in 'handshake mode', which means it handles strobe and ready in hardware and you just have to service interrupts.  After spending time on the PCU board, I see the same pattern:  Port A is gpio, and port B is handshaking.  So I believe the port B is cross connected between the boards, and this is what does interboard communications.
    One curiosity is that in the board shot, I can see a serial jack next to the PIO.  But there are no Z80-SIO or other UART chips on board.  This unit was meant to have an online feature that apparently was never developed.  So, no UART?  Could this be bit-banged serial?  That was a thing back in the day; even the TRS-80 Model I could manage 300 bps.
    I also found an NMI handler.  It's so weird that it might be junk code:
    0066     ; XXX NMI
    0066     nmi_66:
    0066 F5        push    af
    0067 C5        push    bc
    0068 D5        push    de
    0069 E5        push    hl
    006A 21 82 60  ld      hl,  loc_6081+1  ; XXX wut? middle of an instruction; we're probably in the weeds
    006D 22 00 C0  ld      (word_C000), hl  ; XXX wut? we write here, but we immediately over write with the ldir
    0070 11 00 C0  ld      de, word_C000    ; XXX initted from 0238; has IM2 vectors and other stuff
    0073 01 18 00  ld      bc, 18h
    0076 ED B0     ldir
    0078 3E 80     ld      a, 80h
    007A 32 6D C0  ld      (byte_C06D), a
    007D E1        pop     hl
    007E D1        pop     de
    007F C1        pop     bc
    0080 F1        pop     af              ; XXX what, no RETN?
    0081 C9        ret
    So it's blasting the IM2 vector table with bytes from an instruction stream.  It doesn't even blast the whole table, just most of it.  Definitely serious devastations.  But it does this under disabled interrupts, and moreover the routine ends with a RET, which leaves the interrupts disabled.  (Normally you end this routine with a RETN, which restores the interrupts to whatever state they were in before.)  So the blasted table doesn't cause immediate destruction.  And moreover it's not the whole table that's blasted, just most of it.
    cross referencing it to other locations, notably I find:
    02C3     sub_2C3:
    02C6 B7        or      a
    02D6     loc_2D6:
    02D6 CD AC 02  call    sub_2AC
    02D9 C3 00 01  jp      boot_100
    so when set, it does cause a warm boot that reinitializes the system.
    There is another reference:
    55D6 3A 6D C0  ld      a, (byte_C06D)
    55D9 A7        and     a
    55DA C0        ret     nz
    which just exits a subroutine early if it's set.  Maybe because that routine knows that it's all going downhill from here, so don't bother with whatever you were going to do.
    So, it could be that a pushbutton is attached to /NMI and serves as a reset on this board.  I don't know why they would do it this way other than that maybe it permits a more orderly shutdown.  At the same time, the weird code blasting the interrupt vector table is puzzling.
    [Nigel] inquired about port 30h, 38h, and 39h.  I have no idea what those are for yet.  All I can say is that they are written very early in the boot process, and the data does not involve the instruction stream at all.
    I expressed my belief that I should go back to MCU2 and spend some time with ROM 4, which I hadn't looked at much before other than to verify that it does set the system into IM2.  The rest is unexplored.
    [Nigel] has a bit of urgency since his emulator is not running, so he sent me some instruction traces of where it is located.
View all 21 project logs
Nigel Barnes wrote 11/04/2024 at 13:20 point
I'm currently working on emulation of the CEFUCOM, and have the majority of the hardware mapped to IO ports. I'm interested in your interrupt findings, and anything you can work out about how the two Z80 boards communicate with each other via the Z80PIO's.
ziggurat29 wrote 11/04/2024 at 13:59 point
Oh sure!  We think alike that the added PIO is for inter-board communications, and I haven't spent much time on the second board yet.  I figured this board controlled the second, and so would be better to go top-down since I don't have schematics.
Sorry I haven't posted the listing itself yet; every time I have an epiphany I get excited to disassemble more, and the writing the log posts takes time as well, and then there is so little left for the rest of life.  I'll clean up what I have presently and send it along.
Interesting you mention the emulator because I was just about to break down and make an emulator for my own purposes.  In my case it was to be just for research so I could single-step some code to help follow the data. (My mind sometimes gets boggled trying to track that mentally with just the disassembly.)
