The coding portal gets a slight makeover. We make the code editor larger, with a smaller console (so that it renders nicely on small screens), and add in more activities that you can load in to play, and load the solution to check.
![](https://cdn.hackaday.io/images/527651730470531023.png)
![](https://cdn.hackaday.io/images/1247301730470540031.png)
Source code for the wheel robot is also in the making and coming to the portal shortly.
