The C-Beam structure is often used with nema 23 motors, so to use it with nema 17 motors, I had to design a separate motor mounting structure and at the same time be able to change the clearance between the motor and the C-Beam to suit different lead screw lengths.
I looked for several ways to mount the 3D printer head to the chassis and this is the option I chose, this option allows me to change the distance between the printer head and the chassis, it is more flexible.
I used available pcb copper foil and mica sheet to make the printing table.
Another solution to a failed printhead mount.
TRAN.VINH.QUANG
