#3 project log
A project log for Making a mini 3d printer using C-Beam aluminum
Making a mini 3d printer using C-Beam aluminum frame
tranvinhquangTRAN.VINH.QUANG 05/17/2025 at 04:410 Comments
The plastic roll holder is located at the back and is simple.
Next is the arrangement of the control circuit mounting position and wiring. Initially, the control circuit is arranged on the back of the C-Beam.
To make wiring easier I lowered the control board position.
