Hackaday.io Hackaday.io
Sign up Log in
Spectro-scopy-metry-graphi-cally | GinScope
Spectrometer Spectrophotometer Spectrograph or Spectroscope
Adventures in light. while(){Reaching for the highest r.}
FIAT LUX
gintaras-valatkaGintaras Valatka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
1 comments
19 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 2
    • View all
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
2k
1
19
13
Team (1)
  • gintaras-valatkaGintaras Valatka
Join this project's team
  • Hackaday spectrometer projects
hardware
ongoing project
Software
lux light rainbow spectrometer spectrophotometer Spectrograph spectroscope ginscope graph
This project was created on 02/18/2017 and last updated 9 years ago.
Description
Seem like nobody is using Flatbed Scanner, until google told me it's already 10 years old news http://www.candlepowerforums.com/vb/showthread.php?113038-flatbed-scanner-spectrometer-idea
Photos: Basically rainbows and then more rainbows... workbench(quite small), TCS3200(quite big)
Scroll down to project log for YouTube Videos
4. Incoming Data, Diffraction grating, Rainbows, Love & Peace, going back to hacking GinScope.
3. Projecting Spectrum, moving servo by hand, stepper
2. Colourifying "White" Flatbed Scanner light
1. Testing, testing, 1, 2, 3, 4k
Related to: https://hackaday.io/project/19374-ginscope for data logging
Will be back with Scanner teardown and hacks and lasers (if I can manage get some)
After GinsScope acquisition system in place
FFTs to be expec
Files
Flatbed_scanner_as_an_instrument_for_physical_studies.pdf
Interesting find, here is on "USING CDs AND DVDs AS DIFFRACTION GRATINGS" http://www.nnin.org/sites/default/files/files/Karen_Rama_USING_CDs_AND_DVDs_AS_DIFFRACTION_GRATINGS_0.pdf
Adobe Portable Document Format - 1.37 MB - 03/06/2017 at 13:06
Preview
tcs34725_ginscope.ino
Workbench control, todo servos and improvments Watch the video to see the current version in action https://youtu.be/wkT0YgPzUTA todo: improve, servo controls + many more
x-arduino - 7.06 kB - 02/23/2017 at 23:55
Download
Components
  • 1 × TCS34725 COLOR LIGHT-TO-DIGITAL CONVERTER with IR FILTER I2C
  • 1 × TCS3200 PROGRAMMABLE COLOR LIGHT-TO-FREQUENCY CONVERTER
Project Logs
Collapse
  • Lux & Motors old news :D Datum belong to Me! not carrots :D
    Gintaras Valatka • 03/17/2017 at 14:50 • 0 comments
    ONsemi ignored me, so I suspect they do not provide ic samples to hackers!
    Interesting pitch by ONsemi and ability to position itself against the mega trends. Beware, the material is confidential!
    ONsemi claim to be "One of the 2017 World's Most Ethical Companies", - very good if they are, but TL;DR
    http://www.onsemi.com/PowerSolutions/newsItem.do?article=3763
    Giving away data.. ?I trust Raspberry Pi is the perfect companion for your own cloud! ..if I had a team & time... If you wanted AI, you could always try https://mycroft.ai/get-mycroft/
  • 6. Old stock
    Gintaras Valatka • 02/26/2017 at 17:24 • 0 comments
    Jessop 4xDiffration (no longer available, purchased in 2003-4 at Jessops) http://www.jessops.com/accessories/lens-accessories/filters?fh_sort_by=&fh_maxdisplaynrvalues_filter_effect=-1
    Motorised diffraction grating from very similar box http://www.ebay.co.uk/itm/like/282093886093
  • 5 Scanner Teardown, many to go
    Gintaras Valatka • 02/24/2017 at 02:08 • 0 comments
    TBA
    + Attempts to use scanner line array, possibly will be hacking and fooling scanners
  • 4 Incoming Data - Log Me Now
    Gintaras Valatka • 02/24/2017 at 02:06 • 0 comments
    Lux/rgb sensors were mentioned in 2016 https://github.com/soholt/ginscope:
  • 3 Projecting Spectrum, Love, Piece & Rainbows, Unicorns next
    Gintaras Valatka • 02/24/2017 at 02:03 • 0 comments
  • 2 Colourifying "White" Flatbed Scanner light
    Gintaras Valatka • 02/23/2017 at 05:51 • 0 comments
    Scanner warming up, scan, then 240 fps SlowMo + Shake, then back to normal speed for comparison ('normal' assuming 39.178488fps, as was uploaded to youtube)
    FlickeRing Lights, when paused - individual colours can be observed
    If Lucky, catch split colours, as if the light was caught travelling, see the screenshot :D
    So if the lightsaber is white, is it made of rgb? :D
    (no uber tHz/fps cam was used)
  • 1 The journey begins: 4k test
    Gintaras Valatka • 02/22/2017 at 01:27 • 0 comments
    4k test
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Gintaras Valatka wrote 02/25/2017 at 01:33 • point
Share your links under this post. Which spectral databases do you use?
http://osdb.info/pages/about
https://spectralworkbench.org/
http://www.spectroscopyonline.com/
http://www.rsc.org/learn-chemistry/collections/spectroscopy
This a 100% 3D printed Transmission Raman Probe (low resolution) W/built-in cuvette holder/Raman filter
Project Owner Contributor
3D Printable Raman Probe
david-h-haffner-srDavid H Haffner Sr
You wear it and it tells you if you are loosing weight or not.
Automatic Diet Tracker
marekMarek
DIY Helium Light Hotspot replicating a real miner using the Dragino gateway or other. You might be able to mine Helium coins with this setup
Helium Light Hotspot with Dragino LPS8 DLOS8 Miner
akarshagarwal98akarshagarwal98
The 2016 Hackaday Prize
The ZEN of simplicity Making the Complex...Seem Simple
DAV5 V2.1 Spectrometer
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project " Spectro-scopy-metry-graphi-cally | GinScope", please tell us the reason.
Send message
Remove Member
