Spectrometer Spectrophotometer Spectrograph or Spectroscope
Adventures in light. while(){Reaching for the highest r.}
FIAT LUX
Flatbed_scanner_as_an_instrument_for_physical_studies.pdfInteresting find, here is on "USING CDs AND DVDs AS DIFFRACTION GRATINGS" http://www.nnin.org/sites/default/files/files/Karen_Rama_USING_CDs_AND_DVDs_AS_DIFFRACTION_GRATINGS_0.pdfAdobe Portable Document Format - 1.37 MB - 03/06/2017 at 13:06 |
tcs34725_ginscope.inoWorkbench control, todo servos and improvments Watch the video to see the current version in action https://youtu.be/wkT0YgPzUTA todo: improve, servo controls + many morex-arduino - 7.06 kB - 02/23/2017 at 23:55 |
ONsemi ignored me, so I suspect they do not provide ic samples to hackers!
Interesting pitch by ONsemi and ability to position itself against the mega trends. Beware, the material is confidential!
ONsemi claim to be "One of the 2017 World's Most Ethical Companies", - very good if they are, but TL;DR
http://www.onsemi.com/PowerSolutions/newsItem.do?article=3763
Giving away data.. ?I trust Raspberry Pi is the perfect companion for your own cloud! ..if I had a team & time... If you wanted AI, you could always try https://mycroft.ai/get-mycroft/
Jessop 4xDiffration (no longer available, purchased in 2003-4 at Jessops) http://www.jessops.com/accessories/lens-accessories/filters?fh_sort_by=&fh_maxdisplaynrvalues_filter_effect=-1
Motorised diffraction grating from very similar box http://www.ebay.co.uk/itm/like/282093886093
TBA
+ Attempts to use scanner line array, possibly will be hacking and fooling scanners
Lux/rgb sensors were mentioned in 2016 https://github.com/soholt/ginscope:
Scanner warming up, scan, then 240 fps SlowMo + Shake, then back to normal speed for comparison ('normal' assuming 39.178488fps, as was uploaded to youtube)
FlickeRing Lights, when paused - individual colours can be observed
If Lucky, catch split colours, as if the light was caught travelling, see the screenshot :D
So if the lightsaber is white, is it made of rgb? :D
(no uber tHz/fps cam was used)
4k test
Share your links under this post. Which spectral databases do you use?
http://osdb.info/pages/about
https://spectralworkbench.org/
http://www.spectroscopyonline.com/
http://www.rsc.org/learn-chemistry/collections/spectroscopy
