Lux & Motors old news :D Datum belong to Me! not carrots :D
03/17/2017 at 14:50 • 0 commentsONsemi ignored me, so I suspect they do not provide ic samples to hackers!
Interesting pitch by ONsemi and ability to position itself against the mega trends. Beware, the material is confidential!
ONsemi claim to be "One of the 2017 World's Most Ethical Companies", - very good if they are, but TL;DR
http://www.onsemi.com/PowerSolutions/newsItem.do?article=3763
Giving away data.. ?
I trust Raspberry Pi is the perfect companion for your own cloud! ..if I had a team & time... If you wanted AI, you could always try https://mycroft.ai/get-mycroft/
6. Old stock
02/26/2017 at 17:24 • 0 commentsJessop 4xDiffration (no longer available, purchased in 2003-4 at Jessops) http://www.jessops.com/accessories/lens-accessories/filters?fh_sort_by=&fh_maxdisplaynrvalues_filter_effect=-1
Motorised diffraction grating from very similar box http://www.ebay.co.uk/itm/like/282093886093
5 Scanner Teardown, many to go
02/24/2017 at 02:08 • 0 commentsTBA
+ Attempts to use scanner line array, possibly will be hacking and fooling scanners
4 Incoming Data - Log Me Now
02/24/2017 at 02:06 • 0 commentsLux/rgb sensors were mentioned in 2016 https://github.com/soholt/ginscope:
3 Projecting Spectrum, Love, Piece & Rainbows, Unicorns next
02/24/2017 at 02:03 • 0 comments -
2 Colourifying "White" Flatbed Scanner light
02/23/2017 at 05:51 • 0 commentsScanner warming up, scan, then 240 fps SlowMo + Shake, then back to normal speed for comparison ('normal' assuming 39.178488fps, as was uploaded to youtube)
FlickeRing Lights, when paused - individual colours can be observed
If Lucky, catch split colours, as if the light was caught travelling, see the screenshot :DSo if the lightsaber is white, is it made of rgb? :D
(no uber tHz/fps cam was used)
1 The journey begins: 4k test
02/22/2017 at 01:27 • 0 comments4k test
