Delete Button XL
A huge delete button made from scratch
0 followers
Greetings everyone and welcome back, and here's something fun and useful.
In essence, the Delete Button XL is a macropad with a single button that is configured to execute the delete command.
The objective was to design a unique or unconventional macropad with a single button that would be used to execute the delete command. This button would allow you to erase anything by simply hitting it.
Using the delete option, we attempt to remove a few unwanted images.
This body is designed to function and seem as a single mechanical key on a mechanical keyboard. We put four springs to the interior of the macropad, which, like the mechanical key, provides a little resistance when pressed.
The model was created in Fusion360. The Switch PCB and the XIAO microcontroller breakout board were reused from a previous project, and we integrated them both into the 3D model and built the model around them.
Design
Making the 3D model for this project was relatively straightforward. First, we imported the step files of the XIAO breakout board and button PCB that were previously created for the Super NES project.
The Switch PCB was positioned in the center, and we modeled a box-like body around it that would serve as the macropad's main lower body. In order to attach the keycap to the bottom body, we utilized four M3 bolts and four springs. We also created an additional body onto which we installed the switch PCB. This section will also have four holes.
The design's operation was straightforward: when the keycap is pressed, the spring that is attached to each M3 bolt is compressed, pressing the entire assembly downward to produce a noticeable resistance.
The spring mechanism is made up of a separate part that fits into the keycap and serves as a link between the two.
The actuator knob on the keycap hits the push button and records a keypress when the keycap moves just 3 mm downward.
On top of the keycap, we have also modeled a Delete Logo that will be printed in two colors—black and translucent.
After the model was finished, we exported the mesh files and used Orange PLA and Black PLA to 3D print the files. This gave the finished prototype a nice dual-color appearance.
PCB Schematic and Design
We used our previously made Switch PCB and XIAO Breakout board PCB for this project; both were utilized in the Super NES project, but let me briefly review the way they were made.
The Switch PCB is made up of a single switch with four CON1 ports, two of which are linked to one switch terminal and two to another. Furthermore, we have included two mounting holes that are positioned in accordance with the Cad file. The board's outline and the location of the switches were both taken from the CAD files.
A XIAO Board and two CON7 ports, each of which is coupled to an XIAO GPIO, make up the XAIO PCB. Similar to the switch PCB, we added the mounting holes and followed the Cad files for the board shape and XIAO placement.
PCBWAY SERVICE
Following the completion of the board designs, we ordered both PCBs in white solder masks with black silkscreen and submitted the PCB's Gerber data on the PCBWAY quote page.
PCBs were received within a week, and the PCB quality was outstanding. Here, we added a few design elements on the board's silkscreen layer to increase the aesthetic appeal of the project. PCBWAY made the custom layer properly, which shows their great PCB manufacturing capabilities.
Also, PCBWay is hosting its 7th Project Design Contest, a global competition that invites electronics enthusiasts, engineers, and makers to showcase their innovative projects. The contest provides a platform for participants to share their creativity and technical expertise with the broader community.
This year’s competition includes three major categories: electronic project, mechanical project and SMT 32 project
With prizes awarded for the most exceptional designs, the contest aims to inspire and support innovation, making it an exciting opportunity for both professionals and hobbyists to gain recognition and connect with like-minded creators.
You guys can check out PCBWAY if you want great PCB service at an affordable rate.
DELETE BUTTON v1.f3d
fusion - 2.16 MB - 11/06/2024 at 14:52
Download
Frame.stl
Standard Tesselated Geometry - 300.67 kB - 11/06/2024 at 14:52
Download
DELETE BUTTON v3.step
step - 1.30 MB - 11/06/2024 at 14:52
Download
Switch Mount.stl
Standard Tesselated Geometry - 543.83 kB - 11/06/2024 at 14:52
Download
TOP.stl
Standard Tesselated Geometry - 229.77 kB - 11/06/2024 at 14:52
Download
View all 8 files
  • 1
    PCB Assembly process
    • The PCB assembly process was basic. We began by assembling the switch PCB, which simply required a push button, which we positioned and soldered from the board's bottom side.
    • After that, we begin the XIAO Breakout board construction procedure by positioning both CON7 female header pins in their proper locations and soldering their pads from the PCB's bottom side.
    • At last, we added the XIAO M0 in its place using the header pins.
  • 2
    Frame Assembly process
    • In order to begin the body construction, we place the Switch Circuit holder part on top of the lower frame using M2 screws.
  • 3
    Button Actuator Assembly
    • The button actuator assembly, which is made up of the keycap and spring mechanism, is then prepared.
    • This procedure begins with the installation of four M3 bolts in the spring mechanism part's mounting holes. Next, the spring mechanism part is inserted into the keycap, and the two are joined using M2 screws.
    • Next, we insert a spring into each M3 bolt. The spring is taken from an old Anet A8 3D printer's bed assembly, and the keycap assembly is essentially made using the same mechanism as the 3D printer bed
View all 9 instructions
