Hackaday.io Hackaday.io
Sign up Log in
Skate SAO
this is a proof of concept for using fingerboard trucks on PCBs
davedarkodavedarko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
128
0
6
6
Team (1)
  • davedarkodavedarko
Join this project's team
  • github repo
ongoing project
Related lists
Simple Add-on badges
SAO / Simple Add-on badges. Message me if you think I've missed one to add.
Dave's Badges + Simple Add-Ons
My Simple Add-Ons SAO and badges
This project was created on 11/08/2024 and last updated a year ago.
Project Logs
Collapse
  • found some more trucks
    davedarko • 11/08/2024 at 19:04 • 0 comments
    For supercon I populated 4 of these boards that I made for the Supercon Add-on contest, but didn't publish before bringing them to Pasadena. These 10 packs of the trucks reduce the BOM considerably! There's probably something you can do with the UV PCB stuff, basically print your favorite deck in small and then add trucks to it.
    https://www.aliexpress.com/item/1005008003174723.html
View project log
Log In/Sign up to comment
Sign up with Github
OR
A method to add a layer of etch resist to a PCB without toner or laser printer.
Project Owner Contributor
Tonerless PCB Etch Resist (UV Exposure Method)
flcfl@C@
Actually just an adaptation of an existing guide to the better-available Lexmark E360d
haxmark – Direct Laser PCB Printing
fruchtifruchti
Make a custom PCB ruler using my open source PCB rulers
Make your own custom printed circuit board ruler
ian-dunnIan Dunn
using some tricks I learned to create a pcb
stranger things badge
davedarkodavedarko
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Skate SAO", please tell us the reason.
Send message
Remove Member
