[P] 55mm KW11 Microswitch
A project log for Tetizmol [gd0153]
A Tetwice-layout keyboard designed to be abysmal.
kelvinakelvinA 12/02/2024 at 09:220 Comments
Precisely 50pcs
The switches arrived and here are the specs:
Sound profile comparison
Below are screenshots on the sound profiles. The bluish graph moves downwards, so the most recent noise would be at the top edge of it.
KW11 switch from 10cm away
KW11 and blue-mechanical switch from 40cm away
