After a few tests with walking, I decided to not give it a huge head after all. I tried a number of different heads (including several acrylic globes from a crafts store, a doll's head and a lightbulb) and finally settled on a cardboard outline. This is something that an 11-years old can see and say "I could do that!"
For now I used the same code for walking as the #Micro:Bob (I just had to swap some pins and adjust trims), but I want to make it controlled from a second Micro:bit.
import microbit
class Servo:
def __init__(self, pin, trim=0):
self.pin = pin
self.trim = trim
self.position = 90
self.set_period()
def set_period(self):
self.pin.set_analog_period(20)
self.write(self.position)
microbit.sleep(80)
microbit.sleep(80)
self.pin.write_analog(0)
def write(self, degrees):
self.pin.write_analog(int(25 + 100 * degrees / 180 + self.trim))
self.position = degrees
def move(self, degrees, delay=5):
if degrees > self.position:
step = 1
else:
step = -1
for position in range(self.position, degrees, step):
self.write(position)
microbit.sleep(delay)
class Robot:
NORMAL_FACE = microbit.Image(
"42024\n"
"90009\n"
"00000\n"
"61016\n"
"27972\n"
RIGHT_FACE = microbit.Image(
"24024\n"
"09009\n"
"00000\n"
"81001\n"
"28952\n"
LEFT_FACE = microbit.Image(
"42042\n"
"90090\n"
"00000\n"
"10018\n"
"25983\n"
def __init__(self):
self.feet_servo = Servo(microbit.pin2, -2)
self.left_servo = Servo(microbit.pin1, 4)
self.right_servo = Servo(microbit.pin0, 4)
microbit.display.show(self.NORMAL_FACE)
def right_step(self):
microbit.display.show(self.RIGHT_FACE)
self.feet_servo.move(120)
self.left_servo.move(60)
self.right_servo.move(60)
self.feet_servo.move(90)
def left_step(self):
microbit.display.show(self.LEFT_FACE)
self.feet_servo.move(60)
self.right_servo.move(120)
self.left_servo.move(120)
def right_half_step(self):
microbit.display.show(self.NOLRMAL_FACE)
self.left_servo.move(90)
self.right_servo.move(90)
def left_half_step(self):
def walk(self, steps=1):
step = 0
for step in range(steps - 1):
if step % 2:
self.left_step()
else:
self.right_step()
if step % 2:
self.right_half_step()
else:
self.left_half_step()
robot = Robot()
robot.walk(8)
So this is a successor of the #Micro:Bob robot, that would be a little less "gangsta". I designed a PCB for attaching everything together -- the micro:bit, the servos and the battery -- so that you don't have an ungodly mess of wires held together with two-sided tape. I also left some extra holes in the PCB to which you can solder paperclips, to build on top of it and make it a little more interesting.
I found a nice method of mounting the micro:bit to the PCB without using the bulky edge connection -- just use loops of wire made out of paperclips, and plastic bolts (to not damage the micro:bit). The servos fit right into the slots -- I just made the screw holes a bit too tight, had to enlarge them a bit later. The battery holder is still attached to the backs of the servos with a two-sided tape -- there is no room on the board for a different way of attaching it, unfortunately.
In hindsight, I should have made more sockets for the servos -- letting you to plug several servos to the same pin, so they move together, so that you can make hands that move together with the legs, etc. -- maybe in the next version.
