- Using a stst switch as its the one u csn take off the razor side on & off switch. It's the same
I had to make a battery cover as the razor don't have much room . Then work out the wiring to it . You may be thinking why I did not just get a 36v controller. Lol I did 3 off them , one I may of got it wrong , but the others I no I put all the wires together & thy all did not work . & got no wee with the seller . So I tryed the standard controller. The fets inside rated to 70v & by the look of it shod of worked . But puting 36v it just clicked the relay. But u can bypass it . But it will fry the moss fet . So now I am bypassing it .
Running the 36v to the switch and 350w 24v motor to switch. Overvolting it . 350w overvolting works out at 700w motor . That's y I stayed with 24v .
Jbarlow1007
Ampeater
Mark Kelsall
Álvaro Satué
