1Step 1
36v Three battery
2Step 2
3Step 3
as u can see had to make a battry Holder . As there is only room for two battrys
4Step 4making sure I use the relay
5Step 5
6Step 6
Having the 36v pack done u then fit it so it all fit nice . Then to wire the loom together taking to end o
7Step 7
- Using a SPSt switch on off . It came with the scooter so all good
8Step 8
- This is the grip that e200 use its a twist & go but no control over speed it just like a switch. That's y I had this idea.
9Step 9
Charging can be a problem. So I use a 12v charger for one battry. And the 24v ones I use the razor charger .
10Step 10
- as u can see I am charging one 12v that side
Jbarlow1007
