Mini adapter board for Cirrus Logic WM8524CGEDT I2S Stereo Audio DAC. 24-bit, 106dB SNR. Eagle 7.5 Files. Dual RCA line-level outputs, which are also available on the pin header.
Breakout board for 54 pin TSOP SDRAM, suitable for MT48LC16M16A2. Eagle 7.5 Files. The header pads are designed to accept Mill-Max 311-93-164-41-001000 machined pin sockets, and allow them to seat deep in the board. The long pins on this model allow the adapter to be plugged into a solderless breadboard and still accept pins in the sockets on top. :)
