11Step 11
The next step is place the power system in the right place ( using double-side tape, to paste the circuits in the front vertical side), solder the main AC power to the adapter circuits and get the 5V and 12V power outputs. The 5V are used for the speaker system and the external device. The 12V delivers power to LCD screen and the fan.
12Step 12
The sound system is based on a Genius Speakers SP-U115. For this I take off the circuit and speakers from the case.
13Step 13
The sound system is mounted using the deatached circuit and the individual speakers. Here I've soldered the 5v power to the circuit, the audio input and mounted the speakers in the lateral holes. Thus the projector it's almost done.
Edit
14Step 14
Cut the stick of each 70mm magnifying glass. Then, glue all together. Finally add one of those sticks to the center of the group.
15Step 15
The last step is the focus system. It's composed by the four 70mm magnify lenses and a holder througt the top of the box's cover. In this way you can move the lenses group to adjust the projector focus, and the light can be projected to the wall via the front hole.
