Conclusions & future work
03/05/2017 at 17:06 • 0 comments- Using a smaller LCD display gives better results due to the ligth could shine the entire image. It also allows to use a smaller magnify lenses and reduces the final size of the proyector.
- More power is always better, then i'm planning to upgrade the proyector with a 30W or 50W Led.
- Another useful upgrade could be add a condenser lens to the LED to harness the light in a more efficiency way.
- The AV compatibility is good and cheap to use with common entertainment systems. Now I wanna use the projector with a Raspi via Picast to play movies and content using my phone with internet access.
Results
03/05/2017 at 16:47 • 0 commentsHere are some video of the results. Is important to remark that the video quality affects the real visibility of the results, however the light is most focused in the center and the corners are darker, but is very acceptable to see movies and series. The quality decreases when the scene show open planes, for example in a tenis game he ball becomes almost invisible.
