This took about 1.5 hours today to build. I suck at soldering or it probably would have been faster. For influxdb and Grafana, I simply followed the instructions on the respective websites.
I'm thinking I might add some calibration code to the ESP code just to fine tune things a bit, but for now, everything is working.
The Arduino OTA stuff for the ESPs is really great. Makes modifying and testing ESP code so easy!!!
GOAT INDUSTRIES
Cayenne
Stefan-Xp
muzi
I'm running the code on a esp-01 512. It runs fine. I'm running the Python code on a RPI3 with Python 2.7 because the print statements looked line Py 2.
The first post the pi gets looks great but the subsequent one bombs with about 4 error messages. One is trying to write to 10.0.1.202:8086.
Anyway; I'll post the full error string if you think you can help.
Update: I commented out all below print addr {0}, data and it works fine.
I'll do my own printing.
Good project ! I'll be integrating it with this program
(https://github.com/engineertype/MAX31855/tree/master/MAX31855/examples/MAX31855x8) running on a esp-12.
