3D printed linear servo's used to drive a small Delta robot
This is the first attempt to use 3D printed servo's for a Delta robot.
I am now working on the Arduino software...
- 37.00 bytes - 03/05/2017 at 15:04
- 55.00 bytes - 03/05/2017 at 15:04
- 61.00 bytes - 03/05/2017 at 15:04
- 43.00 bytes - 03/05/2017 at 15:04
Print the .stl files preferrably without brims, they are difficult to remove. It may be necessary to sand the beams in order to fit.
Please inform me if the .stl files are not in the correct size....
When constructing, set the servo's in the middle position, set the beams in the middle position and then fix the gears in their middle position.
View all instructions
Looks like a Stewart platform
Bryan Herrera
dannyvandenheuvel
Roger Rabbit
KO
Yes, delete it Cancel
You are about to report the project "Linear Delta Robot 3D printed", please tell us the reason.
