1Step 1
Print the .stl files preferrably without brims, they are difficult to remove. It may be necessary to sand the beams in order to fit.
Please inform me if the .stl files are not in the correct size....
When constructing, set the servo's in the middle position, set the beams in the middle position and then fix the gears in their middle position.
middelbeek
