Electric roof brush v1 [FAIL]
I need to clean my roof so why not creating a usefull tool.
"Tired of cleaning your roof by hand?" This innovative electric brush was designed with this in mind. Designed to make roof cleaning easier, it would effectively remove moss, lichen and other dirt effortlessly. Thanks to its powerful motor and rotating brushes, it would offer a practical and quick solution to restore your roof to its original shine."
[Spoiler alert] This version doesn't work... wait for v2
3dmodeling.zip
x-zip-compressed - 5.57 MB - 11/24/2024 at 18:14
Download
  • Version 1 conclusion
    f4drj11/25/2024 at 10:32 0 comments
    I thought motor was powerfull enough but unfortunatelly not.
    Tests was done on smooth floor and on real tiles which was significantly worth.
    When scrashing a little bit a surface, friction is much higher than the motor can reach.
    Design is good but mecanic is not.
    Second version of this roof cleaner will contain two brushless motor and Herringbone gears.
    More improvement will also be no remote wiring and "power back pack". Battery will be hosted directly inside the brush.
View project log
  • 1
    3D modeling
    All begins with a 3D modeling.
  • 2
    3D printing
    2 sides, 2 axes, 2 washers and a T for water tubing, almost 20H later
  • 3
    Assembling
View all 6 instructions
