Smart Multipurpose Battery Tester
Do you doubt! If your Rechargeable Batteries are fake or real? This Smart Tester can charge and discharge your batteries on a single board.
Starting from
$48.59
opengreenergy has 114 orders / 9reviews
Ships from India
This is an upgraded version of my earlier Arduino Nano based Battery Capacity Tester V2.1, The board featured discharging of batteries only. And it was depended on the connection via Screw Terminal.
Taking the feedback and tinkering on the parameters of the batteries, I learnt that most the users are either using the 18650 Li-Ion cells or the Li-Po cells.
This new Battery Capacity Tester V3 is now "Smart Multipurpose Battery Tester" not limited to evaluate the capacities of the Battery but also calculates the several parameters like the IR Test, Analyse Test and Charging Test.
So, now users can use the single board by Plug in the battery > Charge it with the "Charging Mode" > Analyse the battery and > Test the IR of the battery.
So, evaluating the Battery Parameters for a Salvaged/Old battery is now easy and stands as the Most Essential tool on a Maker's Workbench.
Additionally, such a tool helps in preventing batteries from landing in Landfills,
In recent years, the market has been flooded with low-cost batteries, many of which originate from unregulated manufacturers. A significant concern with these batteries, is the inaccurate labelling of capacity. Often, these batteries claim to have high capacities sometimes exceeding 10, 000mAh at prices that seem too good to be true. In reality, many of these batteries fall far short of their advertised capacity, providing poor performance and posing potential safety risks due to overcharging or overheating.
For consumers and hobbyists who rely on batteries for DIY projects, RC models, portable electronics, or even solar power setups, it is essential to ensure that the batteries they purchase live up to their promised specifications. Unfortunately, distinguishing between a high-quality battery and a low-grade, falsely advertised one isn't always possible by appearance alone.
This is where our device DIY Smart Multipurpose Battery Tester becomes crucial. It allows users to verify the capacity of the batteries they purchase, helping them avoid the pitfalls of using fake or low-quality batteries.
Earlier, I developed the Battery Capacity Tester V2.0, which was designed primarily for discharging batteries to measure their capacity. However, it lacked some essential features, encouraged the development of an upgraded version.
👉 My Book : DIY Off-Grid Solar Power for Everyone
You can order my Book on Off-Grid Solar Power from Amazon
The Complete Project is available on my Tindie Store for purchase, and you can use it Out-of-the-box.
What is New in the New Version?
The earlier version was designed solely to discharge the battery for capacity testing. However, in this version, users can both charge and discharge the battery, effectively turning the device into a battery charger as well.
The following are the major upgraded features compared to V2.0:
1. XIAO ESP32 Microcontroller:
The new version uses the XIAO ESP32 instead of the Arduino, providing a smaller footprint while adding WiFi capabilities. This allows for remote monitoring and control, enabling users to track battery testing results from anywhere.
2. Integrated Charger Circuit:
Unlike the V2.0, which required an external charger to fully charge the battery before testing, the new version features an integrated charging circuit. This allows users to charge and test batteries in one go, making the process more streamlined and convenient.
3. Compact SMD Current Sense Resistor:
This version replaces the bulky ceramic resistors used in V2.0 with a compact SMD current sense resistor. This not only saves space but also improves efficiency by reducing heat buildup, making the tester more compact and easier to handle.
4. Onboard Battery Holder:
It includes a 18650 battery holder directly mounted on the PCB. This enhancement removes the need to connect batteries externally through screw terminals, which was the case with the V2.0 model. Now, users can simply insert their 18650 battery into the onboard holder for quick testing. Additionally, a JST connector is provided for connecting LiPo batteries or other battery sizes that don’t fit the 18650 holder, offering more flexibility in the types of batteries that can be tested.
5. Firmware Upgradtion:
The current firmware now supports four modes:
  • Charge Mode: Direct battery charging with the built-in charger circuit.
  • Discharge Mode: Continuation of V2.0’s battery capacity testing by discharging.
  • Analyze Mode: Automatically charges, pauses, and discharges to measure true battery capacity.
  • IR Test Mode: Measures the internal resistance of the battery condition evaluation.
6. Cutoff Voltage Setting: Users can now set the discharge cutoff voltage using push buttons and the OLED display, eliminating the need to modify and re-upload code.
Step 1: How It Works
The device working...
Cover.stl
Top cover Fusion File
Standard Tesselated Geometry - 892.86 kB - 12/01/2024 at 12:48
Download
Housing.stl
Housing/Base Fusion File
Standard Tesselated Geometry - 411.31 kB - 12/01/2024 at 12:47
Download
Buttons.stl
3x Buttons Fusion File
Standard Tesselated Geometry - 412.88 kB - 12/01/2024 at 12:47
Download
Smart_Multipurpose_Battery_Tester_20241025 (1).ino
Arduino Code!
ino - 28.08 kB - 12/01/2024 at 12:47
Download
  • 1 × XIAO ESP32C3
  • 1 × PCB
  • 1 × Other Passive Components
View project log
Open Green Energy wrote 12/03/2024 at 16:35 point
Hi Alexey, Yes! This project is made under Open Source but Non-commercial 4.0
Regards
Alexey Vazhnov wrote 12/03/2024 at 15:58 point
Thank you!
Is this project available under some FOSS license?
